#1061
Re: Project LQ4 - V8 S10 - Rear end stuff...
#1062
Coming back to the party pretty late. Couldn't you swap the gears from the new rear into the old and save the cutting/welding?
#1063
11-17-2017
BillBooost37
For sure. Certainly an option. Like I've seen you say many times before, anything is possible. I chose to modify a completely different rear end for a couple reasons;
To buy just the ring and pinion gear (even a used set) would be nearly half the cost of a complete junkyard rear
Installing a gear set requires tools I don't currently own (dial type inch lb torque wrench for the pinion pre-load), dial indicator with mag base...
I would also need an instal kit (crush sleeve and assorted shims to locate the carrier) There's about another $100. Give or take.
Probably the biggest reason is, I didn't want the hassle of setting up a new ring and pinion set. Backlash, tooth pattern, pre-load... Forget all that noise. Cut the tube twice, clamp on some angle iron and burn it in. It's a gamble, but it's a pretty safe gamble. Like hitting on 11.
Plus, I was able to sell (at full disclosure of it's condition) the 4:10 rear for $170. That's close to what I paid for the "new" 3:73 rear. I call that a wash.
#1064
#1065
11-18-2017
id be all over #3 too, cut the cable in a clear area and use two cable clamps.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#1066
#1067
#1068
Re: Project LQ4 - V8 S10 - Power steering pump woes
#1069
12-01-2017
work trailer has the same spring set up on the door, we had to replace the whole damn bar and both springs, but changing just one is not all that hard, only tricky part is the pre load on the spring.
#1070
Based on the dust, you know the preload is around 8 turns. The door guys that come to my work paint a stripe down the spring before preload.
For the record : I am NOT a naked meth-head who shoves rocks up my butt.
#1071
12-02-2017
yup, 7-8 seems to be the magic number, this set we just installed had a painted line down both springs, made life easy.
#1072
12-03-2017
Something like 30-32 1/4 turns for a 7' door. I'll cross that bridge when I get there...
So the truck is back together. Pump seems to be working. No apparent leaks. Nothing major yet at least. Now that that is done, I can start on the next piece of low hanging fruit. Trans temps. After about 30 minutes of steady cruising, it'll get up to 220°. I'd prefer it to stay under 200° at all times. Considering I live in the desert and my driving style, that's going to be a tall order. However, I think I have a plan...
A tru-cool H7B 11"x11" 29,200 btu stacked plate oil cooler with a 1600 cfm fan.
Remember that hole I cut in the bed to access the fuel pump...? I'm thinking I can make that functional. There should be some airflow through when cruising, then when the fan kicks on, it will draw through from underneath.
All controlled with a 190° Derale fan switch relay kit.
https://derale.com/products/electric...ing-kit-detail
Originally, I had planned on putting it entirely under the bed at an angle, but there's just not enough room for an 11" square cooler down there. This one's going to take some time. Got fab work, plumbing and wiring. Plus I gotta make it look good.
#1073
12-03-2017
you are the new master round here...wheres the bowing icon?
#1074
Re: Project LQ4 - V8 S10 - Overkill trans cooler build
#1075
#1076
Re: Project LQ4 - V8 S10 - Side project...
12-29-2017
Picked up my next project today.
It runs, but the wiring needs help. My bride wanted something to tool around on while the boys rode their quads. I need to find a small utility trailer.
Post Thanks / Like - 0 Thanks, 2 Likes, 0 Dislikes
#1077
Just build a second story roof rack on the S-10, ala London bus or car carrier...lol. Looks like a fun machine. You'll have it pulling wheelies in no time.
#1078
Donating Users
12-30-2017
Cool.
Chris B
2009 CX-9
** SOLD ** 2002 GT
#1079
Re: Project LQ4 - V8 S10 - Tuning for MOAR POWER!
#1080
12-31-2017
cheatah faheatah
Pretty sure that would be more than that truck would want to haul. I pulled one leaf and the overload to get the rear down a little. Long term plan is to register and insure it so we can take it on the road.
Bronco Boy
Cool.
Thanks! My wife likes it, so I got that going for me.
