Thread: Project LQ4 - V8 S10 - Sold.
Page 33 of 66 FirstFirst ... 23313233343543 ... LastLast
Results 641 to 660 of 1306
  1. #641 Re: Project LQ4 - V8 S10 - Making noise!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by BrandonHall10 View Post
    Nice! We should be doing some test burnouts very soon. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #642 Re: Project LQ4 - V8 S10 - Making noise!
    Mar 2014
    Tucson
    nice score there. those things are worth their weight in gold.
    I had to buy a couple odds and ends and it'll probably need tires soon, but I'm still pretty happy with it. I bought it just to get the truck to the exhaust shop, and the emissions testing station. Anything beyond that is just a bonus. Maybe once the truck is finished, I'll start looking for w-body's with trans problems to fix and flip. Also need to find a truck willing to give up it's motor for my '84 K10.
    I guess if I break the S10 at the track, I'll be able to get it home too...
    Quote Originally Posted by Bronco Boy View Post
    Yup! Just need to:
    Wire the fans
    finish the intake piping
    Redrill the axles
    assemble the rear
    install the rear
    plumb the brakes
    get the driveshaft shortened, balanced and installed
    get exhaust
    get inspected
    get registered
    get insured
    I'm sure there's something missing... But after all that, yes, BURNOUTS!
    (Five minutes later)
    Rotate tires, and more BURNOUTS!
    (Five minutes after that)
    Shopping for new/used tires
    (Sometime after that)
    More BURNOUTS!
    See a pattern?
  3. #643 Re: Project LQ4 - V8 S10 - Making noise!
    Mar 2014
    Tucson
    Still working on fan wiring. Managed to find just enough real estate on the firewall for the fan relay/fuse block. Not much room for anything else. Installing the HydoBoost should open things up a little.
    The fans came with the female connector end, so that was nice. Just need to add wire.
  4. #644 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    fans done yet?
  5. #645 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    Mar 2014
    Tucson
    Quote Originally Posted by Monday View Post
    fans done yet?
    No.
    But I did confirm that diagram. Low and high work independently, and high works when both are commanded. Just need to finalize everything.
  6. #646 Re: Project LQ4 - V8 S10 - Making noise!
    Jan 2014
    AR
    Burnouts yet then?
    I made a couple good oopsie smoke shows in the GTP today. Thought of you.
    After you get done bouncing up and down in the seat laughing and clapping as you fog yourself... the excitement "wears thin" just like them treads!
  7. #647 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    Mar 2014
    Tucson
    Yeah, I'm sure it will get old eventually, but I've got a couple kids that will enjoy it long after I'm over it. Let's not forget the doughnut/drift factor either. There's more to burnouts that just leaving two straight lines. With the right amount of practice, I should be able to parallel park anywhere!
    I cut out of work early yesterday to pick up my completed housing
    Under $75 to chop the long tube down 2-7/8", fixture weld, and install a new pinion seal (that I provided). All work done by Tucson Differential. http://www.tucsondifferential.com/ We'll see how it all works out, but so far I'm pretty happy.
  8. #648 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    that might be one of the best 35 dollar weld ive ever seen lol
  9. #649 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Parking like this ??? https://youtu.be/FOtQiE-HwAQ Piece of cake!
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  10. #650 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    Mar 2014
    Tucson
    I was going to correct you on that price, but after looking at the invoice, that's probably about right. $65 was the total charge for shortening. About half of that would be the welding charge.
    Quote Originally Posted by cheatah faheatah View Post
    Exactly!
  11. #651 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    at any price thats one buttery looking weld.
  12. #652 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Been a while sine I was on here.
    Coming along nicely I see!
  13. #653 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    Mar 2014
    Tucson
    Quote Originally Posted by 231FUN View Post
    Getting there...
    Finished looming the fan wires. I'll test them out with PCM control tomorrow. Also, my 1410 flange yoke cam today. They are not giving those things away. Cha-ching...
  14. #654 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    nice yoke. i like to dip toast in mine lol
  15. #655 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    May 2016
    Rouge Island
    ^^^^ "The Surgeon General recommends against consuming raw or undercooked foods"...lol Me too, and the home fries.
  16. #656 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    Mar 2014
    Tucson
    You guys are dorks...
    Fans function perfectly under PCM control. Check that off the list. Time to work on redrilling the axles.
    I'll see what McMaster and MSC have to help me out.
  17. #657 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Well, with all the things (I think) I need to redrill the axles on order, it's time to address the spring perch location and angle. Did a bunch of measuring. Here's what I came up with.
    According to my angle finder, the truck frame is at 0°, or close enough to zero that I'm not going to factor it in. The 80e is 4° nose down. So if my thinking is correct, the perches on the 8.8 should be set 38-1/2" apart, and the pinion should be 4° nose up. This would make the trans output shaft and rear pinion parallel. Which, in the end is what really matters.
    I put the 8.8 on a set of stands and leveled it out to the perches. It measures 10° nose up. Not that that matters. Just wanted a reference.
    Couldn't take a picture of the output angle. My phone is my angle finder...
  18. #658 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    4º seems a little high but I've seen worse.
    I'd honestly just shim the transmission mount with some washer to get closer to 1-2º down, then angle the rear diff at 0-1º up because the pinion will want to rise under heavy throttle with a good amount of power. In theory at normal cruise it shouldn't cause any vibrations being only 1-2º different between the two when bumming around.
  19. #659 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    You know... That's not a bad idea. I was really okay with 4°, but hearing you say that, I think I'll get under there tomorrow and see how much I can raise it without touching the tunnel. It would also help with my header/steering shaft clearance. I can only assume they (the motor/trans mount company) engineer it with that much angle to clear the tunnel, but I seem to remember there being ample room above the trans. We shall see.
    Thanks for that input!
  20. #660 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    id wait till the rear is under the truck and on its own weight, then start to mess with the angle. never know until its on the floor.
    you'll be doing a 4 link soon enough who we kidding lol
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
