Thread: Project LQ4 - V8 S10 - Sold.
Page 5 of 66 FirstFirst ... 345671555 ... LastLast
Results 81 to 100 of 1306
  1. #81 Re: Project LQ4 - Another S-10 V8 Swap
    it bent the side of the bed and blew the tailgate clean off so it's not unscathed. nothing that can't be fixed, though.
  2. #82 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    I tore the motor down to the heads for a good cleaning.
    Started pressure washing in the rain.
    I was making good progress, but decided to quit when the lighting rolled in. I'll take another stab at it this afternoon. All the covers and pan are coming off for new gaskets, so I'm really only concerned with making the block clean. All the other stuff can be cleaned individually.
  3. #83 Re: Project LQ4 - Another S-10 V8 Swap
    The rear knock sensor hole looks kinda rusty, make sure to throw the foam crap on the intake away when you re-install it. They just trap moisture in there.
  4. #84 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    It's a mess for sure. The little pin for the sensor actually broke off in the plug. Looks like I'll have to replace the rear sensor and harness.
  5. #85 Re: Project LQ4 - Another S-10 V8 Swap
    thats really common, i had to take the intake off a fireds truck for a knock sensor code. rear hole was like yours. only it it was fill of water.
    i sealed the foam plugs with rtv, left the front and back foam out so air can flow under there.
  6. #86 Re: Project LQ4 - Another S-10 V8 Swap
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    That's a very fuzzy picture. lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  7. #87 Re: Project LQ4 - Another S-10 V8 Swap
    it was taken with a very old cell phone , aka potato lol
  8. #88 Re: Project LQ4 - Another S-10 V8 Swap
    Oct 2014
    Frederick, MD
    potato-phones were a LONG time ago, do we have to bring your age into question again? lol
  9. #89 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    thats really common
    Must be that's why they moved them on the Gen 4 engines. (?) I'm hoping it won't be an issue in the future. I don't plan on driving the truck in the rain. The only time that motor should see water will be when I wash it.
  10. #90 Re: Project LQ4 - Another S-10 V8 Swap
    i dont have a clue how it gets wet. seems odd. my friends truck the engines never been washed, it sits in the rain but is rarely driven in it as its a landscaping truck, so its parked on rain days.
  11. #91 Re: Project LQ4 - Another S-10 V8 Swap
    GEN 4 motors moved the knock sensors because the DoD/AFM that is now in the valley cover. They are also a newer design and likely have a better ability to pick up knock when they on the side of the engine block.
    I have a picture of the knock sensors on my old 2006 Sierra that had 250k on it, they looked great.....
  12. #92 Re: Project LQ4 - Another S-10 V8 Swap
    id love to know how it gets so damn dirty under the intake too. looks like they are al that bad. this one has less then 50,000 on it at the time.
  13. #93 Re: Project LQ4 - Another S-10 V8 Swap
    It has to do something with the draft inside the engine bay I think, it just pushes the dirt in from behind or the rear sides and cover everything.
    The engine bay on my 2012 when I bought it with 94k miles was no where near that dirty. It has seen it's fair share of dirt roads and it seems nothing gets trapped anymore. They also do not have the foam inserts on these 07+ engines.
  14. #94 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    Ahhh... I hadn't even thought about that stuff. Makes sense though.
    Finished washing it. No lightening this time, so I had no hold ups. So much better.
    Let me tell you, Gorilla tape for the win. Held up to all the pressure washer gave it. Granted, I was mindful of what I was doing, but it still impressed me.
    The other day, I ordered the exhaust manifold EGR block off. It was cheap enough, and I couldn't make anything that nice for $10. Well, they sent the intake block off by mistake. I was just going to do the freeze plug trick for that. I even already have it on the shelf. Anyhow, they're sending out the right one on Monday and told me to keep the wrong one. So I'll have both block off's for $10! Things are really lining up nicely on this project!
  15. #95 Re: Project LQ4 - Another S-10 V8 Swap
    Crazy how clean those southern motors stay. The all aluminum block on my truck has some minor pits and oxydation already, though it's nothing a wire wheel couldn't take away if the block was out of the truck.
  16. #96 Re: Project LQ4 - Another S-10 V8 Swap
    I had to replace both sensors and the harness on my Hoe last summer, one of my knock sensor holes had water in it, had to get it all out before I took the old one out.
  17. #97 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    Coming from the rust belt, I still appreciate this. You really see it on something like a transmission case.
    Quote Originally Posted by Slick2500 View Post
    I'm debating doing both even though only one of them looks violated.
  18. #98 Re: Project LQ4 - Another S-10 V8 Swap
    It's recommend to replace both and the harness.
  19. #99 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    Then that's what I'll do. Thanks.
    I had a little free time this afternoon, and the pressure washer wasn't put away yet, so I went nuts. Tired of bumping into things and getting dirty. Not in my garage.
    Trans is clean.
    T-case is clean and ready to be posted on Clist.
    Intake came out nice.
    Even put in my freebie EGR block off.
  20. #100 Re: Project LQ4 - Another S-10 V8 Swap
    Mar 2014
    Tucson
    More cleaning. Throttle body this time.
    Stopped by the hardware store to grab some shorter bolts since I ditched the spacer. Noticed some chafing on the TB gasket so it'll have to be replaced.
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
