Thread: Project LQ4 - V8 S10 - Sold.
Page 34 of 66 FirstFirst ... 24323334353644 ... LastLast
Results 661 to 680 of 1306
  1. #661 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    I hear what you're saying. Remember though, this rear has junk gears in it. If I knew I only had one shot, I'd really dial it in. However, this setup will only be temporary. I'm going to get it close and toss it in. Run it for a while and see what issues arise. Different gear ratio, different pinion angle...(?) I can correct any mistakes or issues when I do the next one. That one will be perfect. I'm just trying to make lemonade from the lemon 8.8 I bought.
    4 link? Probably not. This thing is going to be a DD burnout machine with occasional track time. Not a hardcore race truck. I do see a set of Caltracs in its future though.
  2. #662 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Well there was no way I could shim the trans. There's less that 1/4" between the housing and the tunnel. That 80e is a beast. I guess I'm back to being okay with 4°.
    I did get the perches cut off the tubes. I'll get them all cleaned up tomorrow and maybe tacked back on in a day or two. While the welder is out, I'm going to have to back fill the gouges I made cutting them off. Them Ford welds went DEEP.
  3. #663 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Looks like I'll be trying to do some axle drilling tonight. I think I'll practice on the old obsolete driver side axle before I jump right into the short axles. I'm not 100% sure about the large drill for the studs and what kind of press fit I'll get on the knurling. It's a 12mm stud with a 0.495" shank and the knurling measures about 0.507" (best I can tell). I'm starting with a 1/2" drill. Next step down would be 12.5mm (0.4921"). That seemed really tight, but I guess I'll know shortly.
  4. #664 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I've heard that doing squats is a great way to get ones rear end in shape ? And, yes, practicing on material other than your target goal, is a very wise move.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #665 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Well, First hole drilled.
    The stud is a press fit. Err, more of a small hammer tap fit.
    Not quite as tight as I'd like.
    I have a 12.5mm drill on order... Dang me for not just ordering one right away with all the other stuff. Not a total loss though. While I wait for the other drill, I can use the 1/2" to drill the new pattern in the rotors. I think a 1/2" (0.500") hole should be good for a 12mm (0.472") stud.
    After my one test hole was drilled, I still had time to goob some weld onto the axle tubes and grind it flat.
    Like it never happened.
  6. #666 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Did some running today after work. Hit the hardware store to get a 31/64" drill for the lug stud holes. Drilled a test hole and hammered the stud in. I'm very pleased with the fit. Going to proceed with the good axles. No more practice runs.
    Also hit Orielly's to get another serp belt. After just a couple minutes of running, the old one put the tensioner way out of spec. New one is perfect!
    Here's what I ended up with
    And the first piece of my pressure bleeder came today
    Just waiting on the garden sprayer and pressure gauge. Then I should be able to quickly bleed the brakes by myself after swapping rears.
  7. #667 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Going for broke on the axles. Since these are the alpha version, I decided to use the hub centric rings. Just trying to make sure everything was as close as possible.
    Should be hammering the studs in tomorrow. Probably hit them with the wire wheel while they're bare.
  8. #668 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Got the perches welded on. Here's the setup
    I'm actually not completely embarrassed by these welds. I may attempt to shorten the next housing myself...
    Next step is remembering/reassembling all the 8.8 brake stuff. There will be Googleing involved
  9. #669 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Push to Open GTPkirmet's Avatar
    Sep 2015
    Spokane
    Looking good man!
    98 GP Build?: http://www.grandprixforums.net/threa...-in-particular
    Power :Gen V, 3.6, 10.5mm, HS 1.9s, 105#, SDs, FWI, DHP Tuned, CS144
    Stuff :Gauges, 04 Leather seats, Cool stereo, Pregens, LEDs, Retros
  10. #670 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Thanks! Getting close.
    Rear end is assembled as far as I can go. The rotors are drilled. That cast steel is way easier to drill than whatever the axle flanges are made of. Unfortunately, 1/2" is just a little too tight. Going to track down a 17/32" and open them up just a bit. Also need to order different SHCS's for the Moser cover. I measured the original bolts at 0.307" and rounded up. Shame on me for assuming 8mm (0.315"). They are in fact 5/16" (0.313"). Thanks for the imperial/metric mix and match Ford.
  11. #671 Re: Project LQ4 - V8 S10 - Hear it run on page 31
    Jan 2014
    AR
    SAE and metric together on one ride is a peeve, ain't it?
  12. #672 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    It gets old quick. The motor is pretty consistently metric. The trans is mostly metric with the exception of like one valve body bolt, but the truck and apparently the rear end are just a mish mash of both. That must have been pretty common around the mid 90's to early 2000's. The transition from imperial to metric... Running out old designs/parts with new revisions.
  13. #673 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Jul 2010
    Coquitlam,BC,Canada
    My '85 Bronco was a mish-mash of metric and imperial. F-ing annoying.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #674 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    If I remember right, my '85 K10 Blazer was pretty exclusively imperial. Of course, I didn't do a ton of my own wrenching back in the day...
    Pressure bleeder is "built". Still need to grab a $6 reservoir seal.
    Probably time to start thinking about the exhaust. I'm sure I'll find a way to repurpose the old cats. Emphasis on repurpose. Not reuse.
  15. #675 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    Got the back end of the truck off the ground. Wheels off, muffler/tailpipe out, and E-brake cable disconnected.
    Test fit a wheel
    I wonder how long these will last...
  16. #676 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    you see the light,,,yeah that one at the end of the tunnel.
  17. #677 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Antioch, IL
    get some spin tech mufflers, they sound badass
    2009 Challenger SRT8
    Expert at being gay.
  18. #678 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    The "to do" list is definitely getting shorter Scotty. Essentially. we're down to 1.) Rear end, 2.) Drive shaft, 3.) Exhaust, 4.) Inspection, 5.) Paperwork (emissions/registration/insurance)
    I have a set of Summit brand 2-1/2" dual chambered mufflers sitting on a shelf. I originally bought them for the '84, but I think they will end up on the S10. I really like the way they sound. Supposed to be a Flowmaster 40 series knock off.
  19. #679 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    May 2016
    Rouge Island
    Quote Originally Posted by BrandonHall10 View Post
    Good Ole Abe is just begging for a haircut.... You must oblige....
  20. #680 Re: Project LQ4 - V8 S10 - Getting my rear end in shape.
    Mar 2014
    Tucson
    ^^^ Haha!
    Got (what I think is) the right brake line adapter.
    And my 17/32" drill came today to open up the lug holes, so I was able to get the rotors on the hubs. That allowed me to mount the calipers and run the brake lines. Rear end is basically done. Just waiting on shorter SHCS's for the cover. The 1-1/4" ones were just a little too long. I'm Also thinking I'll need to hack off the lower portion of the sway bar mount to clear the S10 shock. On the left side at least.
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
