it can leak in 100,000 miles from now, its got all new gaskets
Time to do some fabrication!
Wut wut? Hell yeah!
Gonna make a stand for the welder? LOL
I'm stoked. Been too long since I owned a MIG. Ordered a flow meter, hose, and tips. Hopefully I'll be getting a bottle and wire this weekend.
My garage is so small, if I set the welder in the middle I could just about reach anything. Ha! I'll probably just grab another cheap movers dolly from Harbor Freight.
I need me one of those...
my friends got the same welder, but a 140 hd iirc? it fits perfectly on the HF welder cart, also has a small bottle area with a chain to secure it for like 45 bucks iirc. its nice little cart.
it holds the small 15 lb gas bottles iirc its like 2 foot tall ish.
link to it at HF http://www.harborfreight.com/welding-cart-69340.html
Big day today!! My "electrician" finished wiring up dual 220 plugs
My recon grinder and accessories were delivered
Picked up a (FULL) 125 CF tank and Taylor flow meter (previous picture) from a buddy for $200
And the Pig is out!
Let's see how much I can get outta this mess on the Craigslist...
I'll post more pictures tomorrow. I ran out of daylight and ambition.
With those 220's I see a electric oven in your near future (powder coating)
So here's some daylight pictures. Engine bay with the motor fresh out. Nothing done at this point. We'll call this "before"
Packrats. Would you like some hantavirus with that V8? No thanks.
Noticed one of the motor mount bolts was a little.... off. I'd hate to think that it left the factory like this, but knowing what GM's quality control was like in the late 90's, I believe it. I guess cross threads is better than no threads.
Engine harness and ABS harness out
Ready for some pressure washing. Probably pre-soak the really bad spots with super clean for a couple days.
That's enough for today.
Gonna put this here for reference.
PCM Black plug:
1 DRKGRN/WHT - Fuel pump relay control
2 N/A
3 DRKGRN/WHT - VSS output for cruise control
4 DRKGRN - VSS output for instrument panel
5 BRWN/WHT - Malfunction indicator lamp
6 thru 9 - N/A
10 PRPL - Brake signal
11 PRPL - Serial data
12 BLK/WHT - Fuel level module return
13 BRWN - Ignition feed
14 PRPL/WHT - Fuel level return
15 TAN/BLK - Shift indicator control
16 thru 17 - N/A
18 PNK - Ignition feed
19 BLK/WHT - 4wd front wheel lock input
20 thru 22 - N/A
23 GRY/BLK - 4wd low indicator signal
24 LGHTBLU/BLK - Cruise control
We use Airgas too, and yes, as long as your money is green(or whatever color your checks/credit card/debit are, does anyone use checks anymore?) they'll take it. Technically stargon is a shielding gas, it brings impurities in the weld to the surface, so they can be chipped off as slag. 75/25 is what we use as well. Be careful how you transport and store those TBRTTHMBG's , much destructive pressure levels stored inside. The knob to the left of your regulator gauge sets the flow rate, when you purge or pull the trigger on your hand gun, set the flow so that the ball inside just floats to the top, that's plenty.
