Thread: Project LQ4 - V8 S10 - Sold.
Page 13 of 66 FirstFirst ... 311121314152363 ... LastLast
Results 241 to 260 of 1306
  1. #241 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    Got tired of sneezing my brains out every time I sat in the truck to make vroom vroom noises and daydream about smokey burnouts. The headliner dust was out of control. I have a few days before getting into the 80e teardown, so I figured I'd try to fix the sag.
    Headliner out. I only mangled a couple of clips and trim pieces. Nothing that superglue didn't fix.
    Didn't take much to pull the old fabric off. Now for the tedious task of scraping all the old foam off...
    According to Google, Joanne Fabric carries grey headliner fabric. Shouldn't have to twist the wife's arm too hard to get her in there with me.
  2. #242 Re: Project LQ4 - Building a cheaper sleeper!
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    If you wet down the foam slightly, small spray bottle of water, it'll cut down on the dust.
    Soaking it is not recommended. Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #243 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    Quote Originally Posted by WarStryker13 View Post
    Yeah. Probably not advisable on a vehicle with a cardboard backed headliner.
    I'm thinking a cup brush on a 1/4" shank in my hand drill should make quick work of it. I'll do it outside the garage on a day with a light breeze. No problem.
  4. #244 Re: Project LQ4 - Building a cheaper sleeper!
    Oct 2014
    Frederick, MD
    Wear a respirator. lol
  5. #245 Re: Project LQ4 - Building a cheaper sleeper!
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    [QUOTE=BrandonHall10;1445860]
    I do say, Good Sir....... S-10 Convertible/Targa Top?
    Might ruin the sleeper effect, but what an original it would be!
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  6. #246 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    Quote Originally Posted by CHI2000GTP View Post
    Ehhh...
    No doubt about that.
    True...
    I've seen a couple convertible pickups. May or may not have been an S10. For whatever reason, they just don't look right IMO. I think I'll stick with the sealed cab. They don't call Arizona the skin cancer capitol for nothing! LOL
  7. #247 Re: Project LQ4 - Building a cheaper sleeper!
    St. Louis
    I've had good luck just using a wire brush on the headliner backing to remove the old foam. Takes it off fast and leaves it smooth.
    And yes, Joanne's does carry headliner material. Did my boss' 99 F150 with material from there. Was an exact match and had the foam backing as well. Nice and cheap and looks OEM.
  8. #248 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    I ended up using a 4" wheel brush. Held it almost flat, so the bristles weren't very aggressive. Super fast and worked great, but made a huge mess. Not much you can do about that I suppose. Followed up with a green Scotch Brite. I'm pleased.
    Ready for fabric
    Quote Originally Posted by FordMan77 View Post
    Good to know! I think any shade of grey will look fine, and maintain a "plain" look.
  9. #249 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    Oh, I did. I'm sure it helped, but I still got some.
  10. #250 Re: Project LQ4 - Building a cheaper sleeper!
    I remember the headliner in my 83 S-10 was like that, I just ripped the ****er out and left it lol.
  11. #251 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    Quote Originally Posted by Slick2500 View Post
    I thought about that too. I'm speculating, but I think having the headliner will keep it cooler. Even being white, that tin gets hot.
  12. #252 Re: Project LQ4 - Building a cheaper sleeper!
    Yeah I did notice an slight increase in road noise.
  13. #253 Re: Project LQ4 - Building a cheaper sleeper!
    Mar 2014
    Tucson
    This also. My junk is going to be loud enough as it is!
  14. #254 Re: Project LQ4 - Fleet truck sleeper!
    Mar 2014
    Tucson
    Got my headliner adhesive today.
    Won't get the fabric till tomorrow, which left me with nothing to do till then.... So I did this
    Yep. Starting the 80e surgery. The trans felt really sturdy on the bucket. However, I do share the garage with "busy" children (and I actually like them and don't want them to get crushed) so I decided to add some safety to that setup.
    Not going anywhere now. First step was to pull the pan. In spite of the fluid color, I'm pretty happy with how the pan and magnet looked.
    Didn't want to go too far without a manual in hand. That's coming off the printer as I type. I'll get back into it tomorrow.
  15. #255 Re: Project LQ4 - Fleet truck sleeper!
    Mar 2014
    Tucson
    Got the headliner fabric today. Letting it relax for a while to get the creases out.
    It was only $4 a linear yard due to a small blemish in the run.
    Not an issue though. There's plenty of room between imperfections to get a full headliners worth of material.
    There's enough left over to do another as well. I'll roll it up and stash it somewhere.
    And this came
    Just need to find a "professional" to use it. Ha!
  16. #256 Re: Project LQ4 - Fleet truck sleeper!
    GXP Level Member
    Mar 2015
    Tomball
    On the headliner I have always used contact cement and spray it from a touch up spray gun. The 3M 77 and 90 series don't seem to hold up for very long a year or less, but I have a car I did the headliner in 2003 and other than the cuts and stuff it's racked up no signs of falling, the foam is starting to go again though. Plus the contact cement is on there for life and it's cheaper.
    Jeff
  17. #257 Re: Project LQ4 - Fleet truck sleeper!
    Kemmerer, Wyoming
    I wonder if the Mustang wheel has the same bolt pattern as the Explorer rear end that you picked up. I think an 18X8 mustang wheel would be a happy medium of performance and price.
  18. #258 Re: Project LQ4 - Fleet truck sleeper!
    Quote Originally Posted by SgtMarshal View Post
    Yes but everyone and their mom does Mustang wheels.
  19. #259 Re: Project LQ4 - Building a cheaper sleeper!
    Quote Originally Posted by BrandonHall10 View Post
    Spray the top of the roof with that rubberized rattle can undercoating. On the inside obviously.
  20. #260 Re: Project LQ4 - Building a cheaper sleeper!
    Oct 2014
    Frederick, MD
    It's weird, but when you use that stuff for things other than coating the underbody, it's magic in a can. Sound deadening, kicker panel covering, door sill and truck bumper coating, adding texture to interior plastic trim pieces... Even touch ups on truck bed liner.
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
