Thread: 2.2 ecotec rod knock
Results 1 to 13 of 13
  1. #1 2.2 ecotec rod knock
    May 2012
    Cedar Rapids, Iowa
    Okay so my father in law just gave me a 2005 Chevy classic with rod knock. I haven't dropped the pan yet to see how bad it is yet. His son ran it out of oil, then drove it 10 miles to our house. I was reading if the damage isn't too bad you can turn the crank then get undersized bearings. Anybody ever done this?
    I looked on car part.com and the cheapest motor I found was 900. I don't have that kind of money right now so this will be as cheap as possible. There's a you pull it near Herr that I was gonna check out tomorrow, the only problem is I don't have a hoist. Or a truck.
    Does anybody have any advice for a noon?
  2. #2 Re: 2.2 ecotec rod knock
    Malibu? I'd get another motor
  3. #3 Re: 2.2 ecotec rod knock
    Get another motor. Fixing the current one you'll probably be on borrowed time meaning you may get it running and then shortly after it break again. If you can't afford the money right now just leave it parked and save up! Your also going to need a hoist to swap it so either borrow one or get one from Harbor freight or Craigslist or something.
    04 Comp G.
  4. #4 Re: 2.2 ecotec rod knock
    May 2012
    Cedar Rapids, Iowa
    Okay thanks guys. I was kinda hoping it wouldn't come to that
  5. #5 Re: 2.2 ecotec rod knock
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Make sure to get the correct motor. There are variances of the ecotec. I know a guy who got the wrong motor (couldn't remember exactly what was diff) and it was going to be more trouble than it was worth to make it work. I don't think that place would let him return it and he was out $$$
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  6. #6 Re: 2.2 ecotec rod knock
    ^^That.
    There are little differences here and there. Make sure it's an L61...
    Also a good thing to do when everything is out is to remove the cover and clean the ever living sh1t out of the oil passages. They're known to clog up and that's what causes the low oil pressure and eventual knocking.
  7. #7 Re: 2.2 ecotec rod knock
    Donating Users
    Aug 2013
    Michigan, USA
    Make sure the engine gasket is also good. Some of the plastic gasket starts breaking apart after so long, especially with old Dexcool. Better yet replace them before dropping the engine into the car.
  8. #8 Re: 2.2 ecotec rod knock
    May 2012
    Cedar Rapids, Iowa
    I'm aware of the l61. The motor that blew was only in there for a month of so. He just paid 900 to swap it in and then they never checked the oil, which Idk why it was leaking. The motor only had 40000 on it.
    I was thinking about calling a you pull it yard here and I was wondering what to expect? ive never been to one Like do they pull the motors or would I have to? I was planning on doing a timing chain and probably water pump while its out.
  9. #9 Re: 2.2 ecotec rod knock
    Quote Originally Posted by genki View Post
    You pull it yards you pull it yourself but you tend to get the parts for a lot less then if they did for you. Be sure to check what kind of warranty they give you with it.
    04 Comp G.
  10. #10 Re: 2.2 ecotec rod knock
    The downsize is that the cars are usually exposed to the elements and Joe Schmos tend to just take what they need and break everything else in the process so you may get something incomplete and you never know why the car ended up in the yard unless its apparent.
    If it was my choice ill get one from a yard that pulls them there selves and gives you some type of warranty.
    04 Comp G.
  11. #11 Re: 2.2 ecotec rod knock
    May 2012
    Cedar Rapids, Iowa
    Okay thanks guys. I'll look around here and see what I can find. I even thought about rebuilding it and all I can find is forged parts. Talk about expensive.
  12. #12 Re: 2.2 ecotec rod knock
    Oct 2012
    Houston, TX
    This. I would try a larger chain like LKQ. They will have a computer inventory you can search to see what they have in your area, mileage, etc so you can compare and make a good informed decision. I don't recall the specifics, but I believe they give decent warranties on the motor.
  13. #13 Re: 2.2 ecotec rod knock
    Or Moradpartscompany
    04 Comp G.
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. knock
    By 04BlackComp_G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2011, 12:27 AM
  3. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  4. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
