Thread: Anyone know what this noise might be?
Results 1 to 5 of 5
  1. #1 Anyone know what this noise might be?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    The trans am has been doing this for a while, seems to be coming out of the valve cover area on the passenger side. It doesn't bother me much you can only hear it when you accelerate it the way I'm doing it in the video. The valve train and cam are stock by the way. Both belts are new in case anyone wants to know.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Did you inspect the pulleys when you did the belts? Sounds like it could be a bad pulley, or something valvetrain related.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Anyone know what this noise might be?
    Mexico
    I didn't, I still need to check with out the belts installed.
    May 2011
    United States
    I think that would be a good place to start.
    Sent from my Droid
  5. #5 Re: Anyone know what this noise might be?
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Videos suck for diagnosing noise. I heard a click every time you got out of the throttle. Was that the noise you're talking about or is it something constant?
    Pull the covers, they need some sunlight anyway.
    The evil LG8 still refuses to die.
  1. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  2. Tie rod noise
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 12-16-2011, 03:46 PM
  3. noise
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2009, 03:21 PM
  4. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
  5. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
