Thread: Photoshop removing door contact bars needed
Results 1 to 20 of 20
  1. #1 Photoshop removing door contact bars needed
    Sep 2011
    East Jordan, Michigan, United States
    Hello my mind is blank I cant remember what they are called but can someone Photoshop the door contact bars out. I am thinking about getting those removed and filled in but I am not sure about liking them if or not. So can someone Photoshop them out and show me.
  2. #2 Re: Photoshop removing door contact bars needed
  3. #3 Re: Photoshop removing door contact bars needed
    Banned
    Sioux Falls, SD
    Im doing this project in school right now!! I cant wait to see the results!!! Google the G-Force Concept
  4. #4 Re: Photoshop removing door contact bars needed
    Kansas
    Mmmm some G-Force sex!
    SE Level Member gotgtp's Avatar
    Chicago, IL
    That looks bad azz
    2004 Comp G - Bone Stock except visual mods
  6. #6 Re: Photoshop removing door contact bars needed
    Apr 2009
    Maine
  7. #7 Re: Photoshop removing door contact bars needed
    Jan 2012
    Philadelphia
    looks better IMO would look even better with out the pin stripe
  8. #8 Re: Photoshop removing door contact bars needed
    Sep 2011
    Thanks J GTP anyway I did remove the pinstripe look at my build
  9. #9 Re: Photoshop removing door contact bars needed
    Sep 2011
    Can someone shave the handles also.
  10. #10 Re: Photoshop removing door contact bars needed
    Apr 2009
    Maine
  11. #11 Re: Photoshop removing door contact bars needed
    Sep 2011
    Copperas Cove, TEXAS
    that's nice and clean^
  12. #12 Re: Photoshop removing door contact bars needed
    Florida
    Why does removing the door bump guard make it look like a bonne? I like it though.
  13. #13 Re: Photoshop removing door contact bars needed
    Sep 2011
    That looks sweet. I am trying to find a body shop around me that will shave the handles and remove the door contact bars. But the all want to use bondo which I refuse to use.
  14. #14 Re: Photoshop removing door contact bars needed
    Florida
    Bondo, when used correctly, is a great tool. Problem is most places just slag it on as a cheap and fast 'fix'
    When you ask around, ask to see their work in person, any reputable place will be glad to show you their craftsmanship.
  15. #15 Re: Photoshop removing door contact bars needed
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Bondo, when used correctly, is not referred to as Bondo. The proper term, and how you can tell the difference between a pro and an idiot with a spray gun, is body filler or plastic filler. If you see somebody talking about Bondo, they don't know what they are talking about.
    GPONA #1 Cyber Bully
  16. #16 Re: Photoshop removing door contact bars needed
    Banned
    Sioux Falls, SD
    They way we are shaving the door moulding at school are welding the clip holes shut, then grindind the surface, then using longstrand fiberglass resin, then shortstrand if needed, body filler if needed, then glaze. Welding would take to long and it would cause ALOT of warp on the THIN door skin. Ill post pictures when im done.
  17. #17 Re: Photoshop removing door contact bars needed
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by MidnightBlue View Post
    That is the absolute worst way to shave anything. When using proper welding techniques you will see almost no warping on the panel.
  18. #18 Re: Photoshop removing door contact bars needed
    Florida
    I'm pretty sure when I shaved the fenders on my wagon using a sledge hammer and an oxy acetylene torch, that was the worst way.
    Tho, I'm sure spending tons of hours meticulously welding is a few and far between approach. On a nice heavy Chevy, or something of show quality, absolutely. On a ****ing GP though?
  19. #19 Re: Photoshop removing door contact bars needed
    Banned
    Sioux Falls, SD
    Quote Originally Posted by blackspike2710 View Post
    So your telling me you can tell the difference when its all complete?
  20. #20 Re: Photoshop removing door contact bars needed
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    When you have ten pounds of fiberglass sitting on the freeway after hitting a pothole, I think I could tell fairly easily.
  1. Photoshop Needed
    By wa04compg in forum Tires & Wheels
    Last Post: 02-26-2012, 05:57 PM
  2. Can you drive without cross bars (fender support bars) for a short tiem?
    By Hippo Machine in forum Visual/Body Modifications
    Last Post: 06-29-2011, 10:47 PM
  3. Removing door molding???
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 10-12-2010, 03:13 PM
  4. Removing the backseat/trunk door
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2010, 09:06 PM
  5. Removing the door panels
    By TNTSS in forum General Tech Discussion
    Last Post: 05-20-2008, 02:57 PM
