I'll just link my thread to MM, thought some of you guys might have some ideas as well.
THEFT Light flashing, car won't start.
Shoulda kept the Prix! Atleast Ferd circled the problem...
From that thread, it looks like a key issue, but... I would try jump starting the car or atleast checking the battery. I know sometimes if a battery is low or failing, it can cause security issues.
Battery has full charge, I did try that. There's an option with the Trip computer that shows your voltage. The car turns over just fine, just won't start because the fuel pump isn't turning on because of the theft system.
also my Prix had worse problems than this, it was rotting out and rust is a lot harder to fix than a security system.
