can someone give me a detailed description on how to take off my headlights cuz i kno everything else about my car except for the headlights...so if u could jus tell me how to or send sum pictures with the description...thanks
Alright, once you pop the hood, we'll start with the drivers side, stand in front of the head light and look down. You'll see 2 bolts, 10mm I believe, it will be the only 2 right above the light. Remove them. The corner light wil slide forward and then slide the whole light assembly towards the drivers side and it will come free. Repeat same process for the pass side. When you put them back on, there is a flat tab on the back side of the bracket that slides into a verticle slot behind the light. Line that up, slide in, and then push corner light back until bolt holes line up. Reinstall bolts and tighten. Your done. If you still need pics, let me know and I'll get some up as soon as possible. Hope this helps.
