ok right now my 00 silverado is 40inchs in the front from wheel well to the ground and 39inchs in the rear, currently the rear end has no block spacers. i would like to fix the height issue and no im not dropping the front ive been fighting months to get 40 inches and i finally got it. should i put a 2inch spacer in the rear? ( currently have some in a box) or should i buy the autozone 1" block for 34 dollars? so 40 inches in the rear or 41 inches is what im asking. what would look better? higher or even?
thanks.
just check stock height FRONT- 35" REAR- 38"
Okay plain and simple, would the truck look better with the rear slightly raised or should i make it dead even with the front, also if i make it 2 inches taller when i haul something it wont drop as much.
