Thread: Engine swap
Results 1 to 5 of 5
  1. #1 Engine swap
    Apr 2008
    Im sorry if this is the wrong place to post but i have no idea where to put this. If someone knows anyone in minnesota that does engine swaps could you let me know. Thanks
  2. #2 Re: Engine swap
    Apr 2008
    Chillin at the Beach , VA
    What engine are you swappin to?
  3. #3 Re: Engine swap
    I live here. UR LOSN's Avatar
    Rockford, IL
    what are you putting the motor in?
  4. #4 Re: Engine swap
    Apr 2008
    l67 or l32 series 3 in a 01 gp gt. I was told its a benefit to go with the series 3 motor. I wouldnt be restricted to what i could put on it right?
  5. #5 Re: Engine swap
    May 2008
    staten island,NY
    l32 uses return less fuel rails, so you need rails off a 02 or earlier GP, as well as L67 injectors, and connectors, map harness. you need a different throttle body because the L32 is electric. also you need to rig up the evap system for the Gen V, its a bit of work but nothing extremely difficult. L67 would be a little easier because of what i just mentioned above with the L32, only advantage i see is the Gen5, better rods, etc. i would go with the L32 and do it up nice cam. Northstar tb etc, i dunno how your budget is
  1. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
  2. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  3. What takes longer? Heads/Cam or Engine Swap?
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:38 AM
  4. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
