Thread: fuel line identification help
Results 1 to 20 of 23
  1. #1 fuel line identification help
    Donating Users sra_chipmunk's Avatar
    Georgia
    I got a question for you. I am trying to do a steel braided line to my fuel return line. The problem is, is that I cant seem to trace this thing back to the tank. I tried to follow the line down below the brake booster, but then it turns a few tims and I loose it. Not to mention that I blew a CV boot one time and allot of the greese is still flung around everyware. Do you know off hand witch line under the car I need to cut. Here are some pics I took.
    Pic #1
    Pic #2
    Pic #3 (looking twords the rear of the car)
    The line with the AN fitting you see in the pics is the fuel feed line that I had done previously.
    Yeah its a grand prix, so what, wanna fight about it.
  2. #2 Re: fuel line identification help
    Oklahoma
    Take a dremel with a cut off wheel and start cutting them all. The ones that catch fire first are the fuel lines.
    It was just a suggestion
    I dont know which are which from the pictures, but my engine bay is wide open and I might be able to crawl under there and see if I can identify them and relay that info to you. But it would be tomorrow at the earliest before I could do that. I feel like crap right now and desperately need to be in bed.
  3. #3 Re: fuel line identification help
    Donating Users Curtis's Avatar
    Missery
  4. #4 Re: fuel line identification help
    Hoffman/Schaumburg, IL
    Start from the top, have someone pull and move around the return line while you are under the car looking to see which moves
  5. #5 Re: fuel line identification help
    Moore, Oklahoma
    Under the car you'll see the 5 hard lines. The 2 smallest are the rear brake lines and the largest is the feed line which you already have setup. Of the remaining 2, the one to the outside is the EVAP line. That means the other 5/16" line is your return line.
    So looking at this picture of yours here...
    The line on the left of the feed line is your return line which is 5/16". The one on the far left is you evap line. I just got done doing mine not too long ago. I'll post pics when I can.
    Hope this helps...
    Shawn W. Larsen
  6. #6 Re: fuel line identification help
    I live here. UR LOSN's Avatar
    Rockford, IL
    Way to go Shawn!
  7. #7 Re: fuel line identification help
    Oklahoma
    Indeed, great work. Nothing like a fresh memory to get it all organized.
  8. #8 Re: fuel line identification help
    Georgia
    Thanks guys, I ordered this today
    Earl's Performance 165056ERL - Earl's Performance AN to Tube Adapter Fittings - summitracing.com
    I hope that with this, I will be able to do the return line with no more problems.
  9. #9 Re: fuel line identification help
    TDCRacing
    Guest
    So your just doing the return line and not the feed? any reason for this? and you said you were going to the tank with it..so what just right above the tank you will ct the lines there and atach the braided hose to the stock tubing with the an to tube fittings?
  10. #10 Re: fuel line identification help
    Georgia
    Quote Originally Posted by TDCRacing View Post
    I already have the fuel feed line done. I did that a few years back. I am just tired of the ugly return line. Its gay. I wont be going all the way to the back of the tank. Thats just to much stainless steel line and I am not rich. I will be cutting the stock return line right ware it goes under the car under the driver seat and attaching the AN adapter there.
  11. #11 Re: fuel line identification help
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Best spot to cut is there it makes the 45* turn before it turns up the firewall IMO.
  12. #12 Re: fuel line identification help
    Georgia
    Quote Originally Posted by VinnieGTP View Post
    Thats where I put the fuel feed line adapter. Its right before the line curves up to go into the engine bay.
  13. #13 Re: fuel line identification help
    TDCRacing
    Guest
    and the point of this is to get rid of the factory quick disconects?
  14. #14 Re: fuel line identification help
    Moore, Oklahoma
    Mainly to get rid of leak POS quick connects. Those o-rings are a ***** to replace and not worth the time IMO. Besides, with aftermarket rails the braided line looks way nicer, but thats beside the point.
    Another reason to loose the OEM GM disconnnects is to get rid of the potential fire hazzard for good. Several of us believe the GP fires are from the quick connect o-rings instead of the valve cover gaskets.
    Hope this helps...
    Shawn W. Larsen
  15. #15 Re: fuel line identification help
    TDCRacing
    Guest
    cool
  16. #16 Re: fuel line identification help
    Thank goodness for this thread!!! I am doing them right now, and had the same problem
  17. #17 Re: fuel line identification help
    Wichita, KS
    If and when I do this for my car, its going to be AN line from tank to engine. I'm not going to tap into and tap out of the hard metal factory lines, I'm going all the way if I am going to do it.
    ~F~
  18. #18 Re: fuel line identification help
    Las Cruces, NM
    If/when you decide to convert to E85 and see the cost of braided teflon hose, you may change your mind
  19. #19 Re: fuel line identification help
    TDCRacing
    Guest
    vinne- why would you have to use braided teflon hose? you can get 20 feet of -6 for around 70 bucks (wich is still expensive) and where did e85 come in at? I thought we were talking about regular gas.
  20. #20 Re: fuel line identification help
    I went filter up on the feed side and firewall up on the return, probably took 3hours including leak testing, the factory plastic brackets do fit -6an hoses if you remove the plastic tabs that are meant to hold in the solid line....
    My line is nitrile based so it is good for all fuels up to methanol (so the company says) and it was $ 80 for 20ft.....Which is about 3.5 feet too much for my needs, To go tank to engine is about 16ft each way(rough geuss and does depend how you route it.)
  1. Parts are in for fuel line replacement
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 10:00 AM
  2. Pressure Supply Fuel Line
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-26-2008, 10:08 PM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  5. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
