Thread: Advice?
Results 1 to 11 of 11
  1. #1 Advice?
    Jun 2010
    Arkansas
    Hello,
    I'm looking at purchasing a 2000 GTP coupe with extra low miles. The problem is that it's been sitting inside for 2-3 years without being started. What am I looking at, maintenance-wise, to get it back on the road? Should I avoid it? It's in good shape otherwise.
    Thank you for your advice.
  2. #2 Re: Advice?
    Arizona
    welcome to the forums
    '00 GT- nothing special
  3. #3 Re: Advice?
    Apr 2009
    stockton ca
    all new fluids tires plugs wires fuel tank needs drained and a new filter
  4. #4 Re: Advice?
    Willoughby, Ohio
    welcome to the forums, do exactly as torque said and you will be just fine
  5. #5 Re: Advice?
    Jun 2010
    Arkansas
    Thanks for the advice. Hopefully everything will work out.
  6. #6 Re: Advice?
    MO
    yup, he hit them pretty well. Another thing is check the date of the tires, they say you shouldn't leave tires on for more than 6 years after they were made. Rubber wears down alot over time and past 6 years your risk of a blowout goes up.
    <brandonl2000> LMAO D!!
  7. #7 Re: Advice?
    Apr 2009
    Wausau, Wisconsin
    Miles Price Condition?
  8. #8 Re: Advice?
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    my last car had been sitting for 2+ years and i did the usual as stated and it was a good car. only thing i did was 2 tires and timing belt tensioner. just check your hoses, PS lines, fuel lines, BRAKE lines.
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  9. #9 Re: Advice?
    GTP Level Member SuperSport's Avatar
    Michigan
    My 2001 GT Coupe was sitting in the guys backyard for 2 years, outside, uncovered, untouched. He just went out and bought a battery when I went to look at it, and it started right up.
    What you may notice is smoking where the exhaust manifold meets the heads. Oil runs past the valve cover gasket and sits on the manifold. Dont worry, it will burn off in a few minutes.
    When you go to see it, turn the key ON, go to the engine bay and smell for gas. A car that has been sitting that long could have cracked fuel line o-rings and injector o-rings.
    If you decide to buy the car go and fill up the tank to dilute the old gas right away.
    But the real question is, who owns a 2000 GTP and doesnt drive it??
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  10. #10 Re: Advice?
    Jun 2010
    Arkansas
    It's nice to know you guys haven't had much problems with yours. To answer SuperSport's question -- it was part of a guy's collection of cars. Oh well, their loss (not driving it much) is my gain!
  11. #11 Re: Advice?
    Jul 2008
    sumter,south carolina
    how many miles? how much he askin?
    02 GTP with mods 05 GP for DD
  1. possible advice ??
    By GpGt2000 in forum General Tech Discussion
    Last Post: 09-07-2009, 11:00 AM
  2. New guy needs advice....
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 08:23 AM
  3. hello, i'm new here and i am looking for advice
    By millfire517 in forum General Tech Discussion
    Last Post: 03-04-2009, 06:45 PM
  4. Need advice on a GP
    By Brammer in forum Off Topic Discussion
    Last Post: 02-05-2009, 04:33 PM
  5. Need some advice here
    By biggmman in forum General Tech Discussion
    Last Post: 09-27-2008, 03:28 PM
