Well, im nearly brand new with the S/C & GTP scene but I've done a bit of reading up on some things and after putting together a open cone air filter, i thought better of dropping a whole ton of $$ on mods without knowing what was going on with the car.
so my second "major" purchase for my 99 was the Scangauge 2.
My first impressions:
"Pros:" Overall pretty happy with it. refreshes at about .5 seconds so its fairly accurate for a portable casual scanning device. Bright enough to read clearly on a sunny day, and has a dim function so you don't have it blaring at you at night. comes with a function to fine tune your background color (which didn't make much difference to me, but it might to someone). Installed in seconds and was pretty straight-forward to set up, including adding the additional "X-gauge" functions (KR, HP, Engine Torque, BAR). Small size fits in the cubby below the radio nicely, or up on the dash next to the HUD (where i have mine, temporarily)
"Cons:" Doesn't have an oil pressure gauge, which is something i really wanted beyond KR. Some of the gauges it comes with / can be installed are ones i already have ie: MPH, RPM, MPG, remaining oil life, water temp, and some others i can't remember. Engine torque readings seemed very inaccurate (i don't think I'm running with 500 engine torque ??). Sometimes .5 seconds is just not fast enough - i'll have to try full throttle on the highway, because there just isnt enough time to see if its reading properly around here.
so for its price i do like it. im not yet prepared to sped over 300 for a scanner,or later perhaps a scanner/tuner, so this seems like it will do just fine in the meantime.
took some picture of it (sorry for the crappy images -it appears blurry and hard to read, but its my cellphone taking the pics, but i can take some decent legit ones tomorrow if this interests anyone)
Closeup (Dim is on)
Horrible picture, but its location up near the HUD
Full Dash {looks as if you cant read it, but its quite clear}
