Thread: intense "stage" packages
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 intense "stage" packages
    Jul 2008
    sumter,south carolina
    are they worth the money?
    02 GTP with mods 05 GP for DD
  2. #2 Re: intense "stage" packages
    probably not. just take our advice on builds. we will save you money and make a setup more usable and better.
  3. #3 Re: intense "stage" packages
    Apr 2009
    stockton ca
    depends on your build and if theres a quality shop in your area that can do port work and know 3800's
    The better the flow the better the performance and the better you can pick a cam and so on
    Ported heads cost money thats all there is to it zzp and wbody also offer cnc heads for a little less i believe
  4. #4 Re: intense "stage" packages
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    ??? Thinking he's talking about
    Stage 1: pcm tune, intake, pulley, plugs
    Stage 2: rockers and valvesprings.... so on and so forth as the kits get more and more
    In which case, no it's not worth the money at all. Kit comes with a 3.4 MPS but doesn't mention or include the exhaust mods needed haha. I guess they just want you to blow. Unless ofcourse you are talking about their cam/head kits.. Ignore everything I just said
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  5. #5 Re: intense "stage" packages
    Apr 2009
    stockton ca
    oh my bad i tune those bs packages out lol not worth it at all
  6. #6 Re: intense "stage" packages
    Package is actually FAIL.
    Read my Safely Modding your 3800 thread.
    That is all.
  7. #7 Re: intense "stage" packages
    GTP Level Member tazyboy28's Avatar
    home town
    for the safely modding your 3800 can that be used with newer models as well?
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  8. #8 Re: intense "stage" packages
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Quote Originally Posted by tazyboy28 View Post
    In general the 04+ GenV cars can not run as small of a pulley as the 97-03 Gen3 cars with the same modifications due to the GenV being more efficient and making more power out of the box.
    Retired
    Turbo'd
  9. #9 Re: intense "stage" packages
    Jul 2008
    im talking about the stage 1-4 cam, heads, lifters etc etc packages.
  10. #10 Re: intense "stage" packages
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Dont do it. I ordered the Stage 4 Heads and Cam package from Intense a month or so ago. Sent it all back for ZZP CNC Heads and XPZ build. Hell the 899 CNC heads are completely and i mean every nook and cranny clean. The IS4 Heads had grime still caked in corners and spray painted over. Hell in the drop down for the package I selected Rollmaster Double Roller and received a JP set. They sent a damn GM Timing Chain Damfener when i was going to be doing a Double Roller. Dont Do it. Just take my little experience and go about a better route. Hell get some heads ported cheap off the forum or take your heads in to be ported for half the price and go with say an IS2 or IS3 cam or XPZ or damn custom grind. Its all what u prefer.
    INTENSE Heads and Cam Package dont save u money
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  11. #11 Re: intense "stage" packages
    home town
    Quote Originally Posted by VictorSmalls View Post
    Then how do i go about modding my GT if its not the same.
    i was about to go get headers and take care of porting the supercharger etc . . .
  12. #12 Re: intense "stage" packages
    EVERYTHING IS THE SAME...minus the pulley drop and the tuning...you have to get a 04-05 PCM to tune your car otherwise the gas gauge will read in reverse.
    As for the pulley drop it is nothing but running a little larger of a pulley because of the Gen V vs. the Gen III...look at it like this...since the Gen V is more efficient than the Gen III, you don't need as much boost to make as much power...therefore it creates less heat and is less parasitic than a Gen III.
    3.4" on a Gen III = 3.6" on a Gen V
    3.2" on a Gen III = 3.4" on a Gen V
    Follow? Everything about our cars are the same really minus those two things...
  13. #13 Re: intense "stage" packages
    Quote Originally Posted by bbptech View Post
    the JP set is the rollmaster set now. they are made by the same company, sold under different names.
  14. #14 Re: intense "stage" packages
    Banned - Busted For Scamming
    Feb 2009
    i have no idea why everyone wants to hop on the ported head train. unless you are running some high boost i would only suggest a smoothing of the runners/polishing of the combustion chamber.
  15. #15 Re: intense "stage" packages
  16. #16 Re: intense "stage" packages
    Apr 2009
    stockton ca
    ported heads better flow makes sense to me
  17. #17 Re: intense "stage" packages
    Feb 2009
    Well it does matter. If you are not modded extensively it will actually hurt you. Same principle as hogging out the blower too much... you gain flow but you lose air velocity, important to the filling of the cylinders.
  18. #18 Re: intense "stage" packages
    Actually Bio, Yella Terra owns JP now
  19. #19 Re: intense "stage" packages
    home town
    so what your saying is that i should order the 2005 overkill pcm for my 07 gt after i have done the suggested in the mod write up. which includes 180t stat, 104 lites, installing zzp headers, HV3 Upper Insert, Ported Throttle Body, Ported Supercharger Case, then take it down to a 3.4 pulley? did i get it right?
  20. #20 Re: intense "stage" packages
    Re read it again...you should see what what happens when someone tries to install a HV3 on a supercharged car...
    And ported heads only HELP you...they really can't hurt you....especially with flow mods such as headers
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Any way to quiet down an intake during the "warm up" stage?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 01:37 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  4. Feedback/Opinions on the Intense "Shift Kit"?
    By Going Too Phast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 10:10 PM
