Thread: spark plug gaps
Results 1 to 13 of 13
  1. #1 spark plug gaps
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    what would be a good gap to gap autolite copper 606 to on a completely stock car
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  2. #2 Re: spark plug gaps
    Saraland Alabama
    .060 is recommended by GM isn't it?
  3. #3 Re: spark plug gaps
    wamego,KS
    thats what i thought but i figured i better ask plus i didnt know if it be better to go wider so i thought id ask. (i have no owners manual)
  4. #4 Re: spark plug gaps
    GTP Level Member David99GTP's Avatar
    Florida
    Quote Originally Posted by archemedes View Post
    Yes you are correct
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  5. #5 Re: spark plug gaps
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Always check 'em. Some of them aren't pre-gapped.
  6. #6 Re: spark plug gaps
    Banned
    New Port Richey Florida
    My stock gap is .045
  7. #7 Re: spark plug gaps
    wamego,KS
    thanks everyone for the quick response got r done.
  8. #8 Re: spark plug gaps
    Enid,Ok
    How did you like the 3 different answers? Hmmm, who do you listen to?
  9. #9 Re: spark plug gaps
    wamego,KS
    well i wewnt with .060 thats what i thought it was so thats with that here in the next month or so ill be getting colder plugs.
  10. #10 Re: spark plug gaps
    Saraland Alabama
    on the emissions decal under the hood it also lists the gap
  11. #11 Re: spark plug gaps
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    but the car didnt come stock with standard copper plugs, so the gap could be different.
  12. #12 Re: spark plug gaps
    Saraland Alabama
    should still be close
  13. #13 Re: spark plug gaps
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by Toasty View Post
    Doesn't really matter. When you look at enough plug manufactures the .060 or at the very least .059 is recommended. Gaps only tighten up from there based on additional boost (smaller pulley, turbo, nitrous etc) mainly to prevent spark blowout. The only time I've seen a smaller gap recommend versus whatever gap you normally run, mods being equal, is in the side gapped plug write up.
    fwiw although Autolites are copper core, that doesn't mean the center electrode is copper on the outside. Unlike the iridium and platinum which has a light coating on the outside. Only the Brisk and Nology appear to have solid silver center electrodes.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. Spark plug reviews for N/A cars
    By Warhellride in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2014, 04:35 AM
  2. Side Gap Spark Plugs [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2010, 12:26 PM
  3. Anyone know where this plug goes/what it is???
    By LowlyfeGTP in forum General Tech Discussion
    Last Post: 01-23-2008, 04:35 AM
  4. spark plug problem
    By dr456931 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:28 PM
  5. Spark plug Reviews
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 10:06 AM
