Thread: LSX oil pump gears in an L67 cover?
Results 1 to 20 of 24
  1. #1 LSX oil pump gears in an L67 cover?
    I'm not familiar with the LSX motors, but looking at pics of the oil pump it looks like there are some similarities.
    I'm thinking of grabbing an LSX pump, and looking at the possibility of stuffing them in our cover. I'm hoping the crank gear drive is the same. If so, then the cover could possibly be machined to accept the guts of the LSX. Be nice to get a higher flowing oil pump in there.
    Any thoughts?
  2. #2 Re: LSX oil pump gears in an L67 cover?
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Sounds cool, and I know we can debate about it because of differing opinions, but realistically what would be the cost to effectiveness ratio of this? I personally would think a higher flowing oil pump would be worth it and would like to discuss the possible benefits of this further. any side by side pics of ours vs lsx ones?
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  3. #3 Re: LSX oil pump gears in an L67 cover?
    i want some more oil pressure too. this sounds like something that i might be interested in doing.
  4. #4 Re: LSX oil pump gears in an L67 cover?
    Saraland Alabama
    is it a higher pressure or just more volume? If more volume is it going to cause starvation? That is an issue with many performance pumps on SBC engines
  5. #5 Re: LSX oil pump gears in an L67 cover?
    I'm putting a deeper sump pan on my car, so I don't care about starvation personally. The stock pan should really have a baffle in it though.
  6. #6 Re: LSX oil pump gears in an L67 cover?
    Saraland Alabama
    Quote Originally Posted by Ron Vogel View Post
    the issue is it pulls all the oil before it can drain back down, a baffle doesn't help that
  7. #7 Re: LSX oil pump gears in an L67 cover?
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    If you're going to all that trouble why not just go to a dry sump system ?
    Lumpy Gen 3
  8. #8 Re: LSX oil pump gears in an L67 cover?
    Quote Originally Posted by Meemperor View Post
    Because I'm not made of money, and a dry sump would probably scrape speed bumps.
    Doesn't really seem like all that much trouble.
  9. #9 Re: LSX oil pump gears in an L67 cover?
    I live here. UR LOSN's Avatar
    Rockford, IL
    The LS7 oil pan in no bigger than an LS1's, the sump system is based throughout the engine bay. the main canister is in the passenger front of the engine bay....but could be placed wherever.
    in mythbuster terminalogy......It's Plausible. (would be cool to see!!!)
    but if you are planning on using LS1 components, I'd go for aftermarket LS1...instead of just using stock............just my .02cents
    also, wouldnt it be simpler just to have a seperate oilling system off the main feed......and add it to various sections of the block that are starved?
  10. #10 Re: LSX oil pump gears in an L67 cover?
    Williston, North Dakota
    Ron you are crazy
    in a good way though.
  11. #11 Re: LSX oil pump gears in an L67 cover?
    hangover park IL, in the garage working on one of 12 3800's
    ron i believe the best solution is an external wet sump pan, with a ported cover, deleted filter bypass/ported oil filter adaptor, step drilled rear bank main galley and drilled #2&3 mains.
    we just picked up a couple of these at the drag expo
    postive displacment pump volume doesnt do much when it cant get where it needs to be...
    that passage in this block was just .112 past the cam bearing...another block i have measured at .120 so at the least ron stick a wire gauge down there...
    i'm sorry i missed you at the drag expo...i was having an interesting coversation with Jason Coan about 4t65/4t80e FWD converters and gearing ya shoulda been there
  12. #12 Re: LSX oil pump gears in an L67 cover?
    Had the boys with me, and one of them started getting sick as soon as we got there. So needless to say, we didn't stay too long. I spent all Saturday cleaning my carpets, he ALMOST yacked on the dining room floor later that day, quick thinking got him to the sink just in time!
  13. #13 Re: LSX oil pump gears in an L67 cover?
    Rockford, IL
    hey did you ever make the clock out of the block? lol
  14. #14 Re: LSX oil pump gears in an L67 cover?
    jeeze ron that sucks...i take it ya didnt get to make full rounds of the expo?
    Quote Originally Posted by UR LOSN View Post
    no one guessed right...ya'll were guessing too big...thats the scary part lol
    BTW a side benifit to the external pan sump is that your now able to use a full pan windage screen/tray/crankscraper since the restrictive OE pickup/block passages are not used...
    Last edited by turbocharged406sbc; 01-21-2008 at 01:34 AM. Reason: short term memory loss...
  15. #15 Re: LSX oil pump gears in an L67 cover?
    Yeah, I missed a lot of stuff, but I got some new ideas there.
    I was up till 12:30 last night, had to get up at 5am to get showered and packed for my San Antonio flight this morning. I overslept to 6am...taxi arrived at 6:15, made it out the door at 6:16!
    Yeah, poor Max has a 103F fever today. It's a drag being out of town when the kids are sick, but at least it's a little warmer here than Chicago right now.
  16. #16 Re: LSX oil pump gears in an L67 cover?
    Hoffman/Schaumburg, IL
    I would think a high flow oil pump for a 305 would bolt into the 3.8, I even heard the pistons are super close if not the size.... 3.8 / 6 = .6 L per cylinder, 5.0/ 6 = .6 L per cylinder(i know this is different than piston size, but points to a very similar stroke as well), these motors are very close cousins if not brothers....
    oh and did anyone see my dash at the expo, my buddy used it to display some finishes like wood grain and aluminum (all hydro applied)
  17. #17 Re: LSX oil pump gears in an L67 cover?
    Saraland Alabama
    the 305 used the same pump as a 350
  18. #18 Re: LSX oil pump gears in an L67 cover?
    I was there with Mike K. (WBS). LOL, he didn't even notice it was GP dash until I pointed it out. I took some literature, but they quoted us $300 for the GP dash...a little high for mass production. I wanted to talk to him about a run of group buys (maybe some sort of prepay deal), but had the kids with me, and my oldest was really impatient.
  19. #19 Re: LSX oil pump gears in an L67 cover?
    Quote Originally Posted by 02BlueGT View Post
    stroke/deck height is different as well as the piston comp height, bore centerlines are different and the bore is smaller
    the only thing they share in common is the 4.3L V6 is a 90* split journal V6
    sorry i aint one for appearance stuff lol
    did mikeK get to any of the seminars? evidently coan has developed several different stator designs for the 65e converters...
  20. #20 Re: LSX oil pump gears in an L67 cover?
    Toronto, ON, Canada
    Quote Originally Posted by turbocharged406sbc View Post
    Rumor has it you can use 4.3L forged rods in the 3800
    Lumpy Gen 3
  1. where to get tail light cover decal
    By Sinister Drag Designs in forum Chevrolet Impala
    Last Post: 07-28-2016, 10:23 PM
  2. Power Steering Pump Replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2013, 03:28 PM
  3. Gas pump etiquette.
    By Warhellride in forum The Rant Forum
    Last Post: 02-04-2008, 04:23 PM
  4. What are you paying at the pump ?
    Last Post: 01-16-2008, 04:38 AM
