Thread: How does an ECU patch fix a faulty camshaft?
Results 1 to 11 of 11
  1. #1 How does an ECU patch fix a faulty camshaft?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So VW has a recall for some of the 1.8T cars. one of the cam shafts drives both the HPFP and the vacuum booster for the brakes. one of the lobs sheers off causing the vacuum pump to fail, reducing break power, and putting the car in limp mode.
    pretty sever failure. VW finally has a fix.... An ECU reprogram.... How the hell does an ECU reprogram account for faulty camshafts?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: How does an ECU patch fix a faulty camshaft?
    The same way using tap shift throws rod bearings?
  3. #3 Re: How does an ECU patch fix a faulty camshaft?
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by Slick2500 View Post
    Im genuinely not sure what you mean.
  4. #4 Re: How does an ECU patch fix a faulty camshaft?
    You must have missed that thread. Some dude bought a Comp G then the engine blew up 12 miles later, seller claimed it was from using the tapshift to downshift the car....
  5. #5 Re: How does an ECU patch fix a faulty camshaft?
    Sep 2014
    Richmond Virginia
    Yeah Ive been off for about a month or two. Dealing with the new job and school.
    The part that I don't get is that it all seems mechanical. The HPFP has to run no matter what the computer says its mechanically driven by the cam, as far as I can tell so is the vacuum pump. If the failure is metallurgical does that mean that the cam should be replaced? The only thing I can thing of is that the tune changes how the VVT functions, which in my mind would alter the power output.
    My brother is a VW tech and he has no idea what the tune does.... shows how well VW briefs their techs.
  6. #6 Re: How does an ECU patch fix a faulty camshaft?
    SWPA
    Maybe the cams aren't the cause. Maybe they are the effect of another issue.
  7. #7 Re: How does an ECU patch fix a faulty camshaft?
    May 2008
    Schuyler, NE
    I would assume it's due to vvt.
  8. #8 Re: How does an ECU patch fix a faulty camshaft?
    Sep 2014
    Richmond Virginia
    I wont even bother to check the VW forum. Those people cant even change their own oil, the probably wouldn't even recognize a camshaft
  9. #9 Re: How does an ECU patch fix a faulty camshaft?
    hangover park IL
    could be a pressure spike on the HPFP, they could be changing the ecm controls of the pressure solenoid to reduce the pressure/spike upon startup/etc.
    reduce the load, increase component life till out of warranty
    ~James~ Psychotic Gearhead
  10. #10 Re: How does an ECU patch fix a faulty camshaft?
    hangover park IL
    anyone who's dealt with the old school "turn on thump" of older amplifiers....knows what a tiny change of a signal delay on power-up on component life.
    a small change can have quite the effect
  11. #11 Re: How does an ECU patch fix a faulty camshaft?
    Sep 2014
    Richmond Virginia
    Interesting, didn't think about that. It kind of reinforces my desire to ditch the car when the warranty runs out.
  1. Faulty coolant temprature sensor cause no start?
    By tweeder in forum General Tech Discussion
    Last Post: 08-17-2013, 09:27 AM
  2. PCV faulty?
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2013, 10:23 AM
  3. Fuel Gauge Faulty/Circuit Board Issue?
    By tinaolszewski in forum General Tech Discussion
    Last Post: 10-11-2012, 08:24 AM
  4. Faulty TPS Round 1,281,753
    By jwjones in forum General Tech Discussion
    Last Post: 02-22-2012, 02:57 PM
  5. 3.8L SC Random stalls, faulty intermittent start!
    By agentbluescreen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 01:22 PM
