#321
Re: Bandook's 01 Imp, top swap-ified
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#322
Donating Users
06-14-2019
Ah, duh. Yeah, post MAF makes sense. I'll take plenty of time to go through the instructions. Just got the new-mod-in-the-mail excitement. Was torn between rockers and meth, but figured that water/meth is perfect for the Heaton. I wouldn't be as quick to do it on a daily driver, but seeing how little use this car gets it was a no brainer.
Top Swapped 01 Imp
#323
Donating Users
06-14-2019
Thanks Scott for the pics. I'm just gonna drill the blower case. Have a spare in case I mess it up, lol. Nah, I'll be fine.
Top Swapped 01 Imp
#324
06-14-2019
its a npt tap and fitting, so drill it, tap test fit tap some more. you want the end of the injector tip flush or just past flush, if you leave it inside the threaded area it wont mist right.
#325
Donating Users
06-16-2019
What nozzle size u using, Scotty?
Also, I'm thinking there might be a way to pull spark in the event of a pump failure. That's the only thing I'm not crazy about with the kit, there's really no failsafe except for an LED. I have an idea but gonna test it first because it may be a dumb idea.
Top Swapped 01 Imp
#326
06-16-2019
the led light does its job. no way to pull timing. its set. you need to watch your wb. i got my light mounted next tot he wb. i got a red led from another failed project, so i used that, it gets brighter, like if i just get into it enough to start spraying, 6 psi it will be dim if i hammer it it will go full bright.
my last tank i filled up was 3 weeks ago, since then it used 1/2 the tank. as long as your not in boost all time it lasts a good while. while tuning expect to drink up a couple gallons easy.
im using the large injector, but i got a ic ported heads and rockers and it seems to take it pretty damn good. i started out on the middle jet, but found the larger one worked best for me.
#327
Donating Users
06-16-2019
Nice, thanks. I'm gonna start with the middle jet and go from there.
What I'm thinking, there is a wire in the AEM harness:
Boost Safe LS
Out
18
AWG Green 1.7A Low Side output. Grounded when error condition
I could use that, and a n/o relay so when a failure happens it grounds the IAT sensor. Then it's as easy as pulling timing in the IAT/spark map. That's if the IAT reads high when grounded. I'm guessing it does but I need to do some tests.
Kit is on the Amazon truck now. Just thinking out loud.
Top Swapped 01 Imp
#328
06-16-2019
it's based off horsepower I think. I run the big jet too. xp cam, ported heads, gen 5 on a 3.2 pulley
#329
Donating Users
06-16-2019
Just got the kit. Hmm, my engine bay install ain't gonna happen. Dang pics made it look a lot smaller. Pump is massive!
Top Swapped 01 Imp
#330
06-16-2019
bandook
why mine is in the trunk, theres enough wire to make it. i had to add a foot to the pump and level sensor wires to reach them where i mounted em.
#331
Donating Users
06-16-2019
How does this look? Couldn't find any other pics of people putting it in the case. Gotta run to the store and get a tap. Everything else is roughed in and tested.
Top Swapped 01 Imp
#332
06-16-2019
right where the harness is on the front, just to the left of the flange the tb gets bolted to is where mine is. where your looking there might hit the hood, you got a tube leading to it to.
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
#333
Donating Users
06-16-2019
Do you have any close up pics?
Top Swapped 01 Imp
#334
06-16-2019
same location as the gen 3 with tb spacer, but to the left of the flange. id have to go out and take pics for a up close. page back you can see the tube loop into the area it is in too. to the right of the bbv its under the harness pretty much.
#335
06-16-2019
#336
Donating Users
06-16-2019
Too late!
Clears good fine. Went two 3 stores looking for 1/8" npt. Then found one in my tap kit. I think it's beer thirty. Happy Father's day!
Top Swapped 01 Imp
#337
06-16-2019
#338
Donating Users
06-16-2019
Top Swapped 01 Imp
#339
Donating Users
06-16-2019
Top Swapped 01 Imp
#340
06-16-2019
