Thread: Bandook's 01 Imp, top swap-ified
Page 11 of 32 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 632
  1. #201 Re: Top Swap in progress, few questions
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Stock lifters for the win, ls7 lifters are a waste of money you could have spent on other mods unless your stock lifters were bad/ticking.
    Did you measure for correct push rod length with the new lifters? ls7 lifters are an oem replacement but only because they're the only thing available that's close...they're not the same as stock 3800 lifters.
  2. #202 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    Yeah, heads were off when I cleaned all the threads. Don't remember if I used loctite though. I took the oil cap off and stuck my homemade listening device(vac line) in there and it sounds like the rockers. Its just frustrating trying to pinpoint sounds kwim? I'm waiting on a set of 1.9's whenever the seller gets them off the car, so I'll just redo them then. I heard all the hate about the comp bolts, guess I'll get some stockers when I redo them.
    I'm considering getting the pushrod measuring thing-a-ma-jig too. Since I had valve work done I'm feeling I'm close to the edge of spec for the ls7 lifters with stock rods.
    Top Swapped 01 Imp
  3. #203 Re: Top Swap in progress, few questions
    I've never used anything besides the comp bolts, like so many others...nothing but good in my experience.
    Pull the valve covers and check the bolts. You don't want any ugliness because things were flopping around.
  4. #204 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    OK, thanks Bill. Thinking to just blind guess some shorter pushrods. I had 8 thou milled off the heads, and a valve job. Would probably be safe to just buy rods that are 10 thou shorter. Or even more because the valves opened a little when I tightened them down initially. Ls7 specs are .020-.050 from what I've seen.
    Or I could do it the right way and measure exact length I need, I suppose.
    Top Swapped 01 Imp
  5. #205 Re: Top Swap in progress, few questions
    You could start by torquing them down properly. If you are concerned about pr length do a compression test. See if you are low.
  6. #206 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    Yes sir, will do . Ordered the comp pr length checkermajig. Will do a proper check on them and retorqe em all.
    I've always been a little confused about checking length with hydrolic lifters. Do I just crank the engine a few times before checking to keep them pumped?
    Top Swapped 01 Imp
  7. #207 Re: Top Swap in progress, few questions
    Since i have never checked length (see...I torqued them properly after hearing the clatter..lol). Hopefully your checker comes with instructions.
    FWIW, stop being such a girl and pop the VC's off, recheck the torque and smile when you find that one was loose.
  8. #208 Re: Top Swap in progress, few questions
    Buffalo
    The stock lifters have a pretty wide "room for error" range Read up about it for the exact amount
  9. #209 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    Quote Originally Posted by RickyBobby03 View Post
    Yeah, ls7 are .020-.050 I believe. I should be good but I had 2 valve jobs done and the heads surfaced. I'll measure just for piece of mind.
    Top Swapped 01 Imp
  10. #210 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    Checked rockers today, everything is tight and there is no play. Did find a bad pulley, plastic junk so replaced with a new metal one. Think that was some of the noise I was hearing.
    So I put it back together, and had it idling for 5 minutes. Then...it died. And won't start. Fried another fuel pump. Sheesh. The relay was very warm to the touch too, so that confirms the pump was on the way out right? Drawing too much current until it fried? Put new relay in, got 12v to the pump but no whirrr. Hammered the tank but no luck.
    So...I want a frigging reliable pump with no hack job on the canister that I can run to empty. What are my options? How far can you take a stock ac delco? I could do the venturi walbro but I need a new canister too.
    Top Swapped 01 Imp
  11. #211 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    Pulled the pump out and hooked it up to 12v. Nothing. Banged it on the ground and.... boom! It blew up. No, not really, but it did start working again. Hoping just some goo got lodged in there. While I had it out, for the umpteenth time, I hacked it even more.
    Why not I guess. Cut the bottom out and pushed it down about 2 inches more. Still don't trust this hillbilly setup, need something more reliable.
    Top Swapped 01 Imp
  12. #212 Re: Top Swap in progress, few questions
    id cut the whole bottom off but leave 4 little legs to keep the sock off the tank bottom a 1/4 inch or so.
  13. #213 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    That's what I did. I didn't cut up the sides, there are a bunch of holes I drilled there.
    Top Swapped 01 Imp
  14. #214 Re: Top Swap in progress, few questions
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Gotta change your thread title. Its old lol.
  15. #215 Re: Top Swap in progress, few questions
    Apr 2015
    Columbus, OH
    Not a bad idea...don't know how though lol.
    I'm 99% sure my engine noise is an exhaust leak. Yay SD headers! I reused the stock gaskets, and don't think I can get them much tighter. Sounds like front manifold is the culprit. Guess I can try some new gaskets.
    Top Swapped 01 Imp
  16. #216 Re: Top Swap in progress, few questions
    St Thomas Ontario
    click "edit post" on your very forst post on this thread, change title and all done
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  17. #217 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Oh, neat. Thanks
    Top Swapped 01 Imp
  18. #218 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Well, the fuel pump is done. Or I'm done with it. Put a new gasket on front header. Started it up an it died after 2 minutes. No fuel, no bueno .
    Really interested in your opinions on pumps. Will a stock pump be good down to a 3.0 pulley, ported heads, headers, rr's? Plan on doing a cam next spring too. Just don't see much discussion on pumps. Would like to order something tonight. I'm thinking the walbro venturi pump. I'll also have to buy a canister, which I can't just buy the canister alone so I'm thinking of buying a 35 dollar pump on eBay just for the canister. Help?
    Top Swapped 01 Imp
  19. #219 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Paint my cheeks red, but I don't think I have a venturi pump. I was thinking that the dual pickups on the bottom made it a venturi. But doesn't it need a second smaller fuel hose coming off the top to make it venturi? Confused myself again. Just another day in the life of Dook...
    Top Swapped 01 Imp
  20. #220 Re: Bandook's 01 Imp, top swap-ified
    missouri
    Quote Originally Posted by bandook View Post
    yes. that small black hose tells you if you have a venturi pump or not. small black hose = no small black hose =
    2000 Grand Prix 3.8 top swapped gt, headers, ported gen 3 blower, 3" catless downpipe, overkilled tune, CAI, 180, transgo shift kit, C5 front calipers, 12" f body rotors, GMPP sway bars, racetronix venturi pump w/rewire. Coming soon: strut braces
  1. Couple questions regarding build in progress
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2013, 11:03 AM
  2. Top swap Progress
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-15-2012, 05:55 PM
  3. Top Swap progress
    Last Post: 09-14-2012, 07:04 PM
  4. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  5. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
