Stopped in Intense today. I'm gonna just use the heads I have. With my HP goals, the small crack shouldn't be an issue. So with that, I started porting tonight. First time porting cast. I didn't imagine it would cut so easy. So I started with the exhaust, for practice I guess. Basically just cleaned up the casting marks. Not sure if I'm going to try to open them up/gasket match or whatever. But I think they came out OK. I did cut into the valve guide area just a bit. But I don't think it will matter since the guides are just milled from the head and not pressed in, right?
A question about the idler pulleys. Does anyone have the size or part numbers for the 3 pulleys? The ones I have, I think at least one is the wrong size. I got the part #'s from a picture I found, but now I realize that there are different pulleys on different cars. Here is the tensioner bracket I have
When I mock it up the pulley on the tensioner is hitting the other pulley on the bracket. I think the tensioner pulley is 90mm and the grooved pulley is 74ish. I found other pics and it looks like the tensioner should be smaller than the grooved pulley?
My tensioner will hit the other pulley without the belt on because i got a larger diameter tensioner to allow me to use the stock sc belt size.
OK thanks. I bought the smaller belt so I'll get a smaller pulley just in case.
I have been doing some more port work to the heads. Exhaust runners are done. Intakes are roughed in. I'm still not sure how I'm going to finish the intakes. Reading as much on porting that I can, and there's just so much conflicting info floating around. To smooth or not to smooth, or not too smooth. I haven't touched the short side radius because it seems I can really screw it up if I take too much off. Think I'll leave it as is.
Last night I started on the combustion chamber. At first I wasn't going to touch them, but I just couldn't resist. Here's one that I just started on.
And after about an hour.
I blended a lot of the "steps" right up to the valve seat. When I got close to the seats I took the valve out and using my dremel with a pear shaped stone, I smoothed it right to the edge. Still needs a little more work. Might unshroud just a little at the outside edges of the chamber to make them flow into the seats a little better.
Here's a head where left cylinder is untouched, middle is stoned 95% and right is hand sanded a little with 120.
I'll lose some of the L36 compression, but just decking the heads might put me close to where I started. Might end up getting some Cometic mls gaskets that are a little thinner, but I don't know if keeping higher compression is worth it since I'm pullying up anyways.
Gonna wear a better mask next time. Can still taste iron and blowing out rusty boogers is kinda gross.
One head done.
Hope to have the other done by the time I'm called to pick up the blower so I can drop them off to be resurfaced and have valves cut in.
The rest of the exhaust finally came. Looks like I'll still have to buy a piece of 3" and figure out how to get it to mate with my exhaust. He just hacked the end off and its kind of messed up. Can I weld stainless with a gasless flux core welder? Dunno.
I'm still ahead on the deal since he included a couple band clamps, look on the bright side I guess.
I hope your getting rid of the sink trap while your at it. You'll hate that you didn't once it starts bottoming out on everything.
You build a jig like this. Of course it'll be slightly different for you since your missing some of it but you can still do it to have the angle right
http://www.grandprixforums.net/threa...dified+headers
You can use your existing flex but the stock single walled flex that come see it the SD s aren't the greatest. Most will go ahead and replace it, some will just replace it now while it's off. It's up to you.
This is my modified set
Red, your awesome. Thanks man.
So, I've decided I want to go the E85 route now. It's plentiful around me, and it will benefit future mods even more. I ordered a Aeromotive Stealth 340, and I'm working on getting a set of 60lb injectors. Am also going to install the hot wire kit. Found a new machinge shop to finish my heads, mill the HG area and lap in the valves. This guy was so much easier to talk to. Didn't make me feel like an amateur (which i am but there's no need to make it obvious ) and he happily answered my questions and gave me some visual ideas with some parts he had laying around. Plus he actually gave me a time to expect them to be done! This week!
So, If i can get the last few parts...injectors, FP wiring, I think I'll be starting the install Saturday. I ordered a sheet of CE phonelic, gonna try to make a thermal spacer for the M90. Never cut this stuff before, so it depends on how easily I can get it done whether I use it or not. I've always wanted an excuse to work with this stuff, so this was it. Plus, if it comes out good it is only 30 bucks for 1/2" spacer.
I think I'm gonna bite the bullet and go with dhp tuning. I called AVT. He's out of the office today so probably get it ordered tomorrow. I've been reading a bit, and know I've got a LOT to learn. I'm having a little trouble getting going in the right direction though.
For those who have done a top swap and tuned it, where did you start? Do I start with my stock bin on my l36 pcm, or do I flash an l67 bin into my pcm? Or get an l67 pcm and go from there? I have the zzp wiring kit for the map and bypass.
Ideally, I would like a nice foundation to build on, so flashing something that's close would be nice, then tweak it from there.
Should I get a wideband? Just the o2 and the box, don't really need a gauge with hpt do I? Really don't want a gauge pod in the car, trying to keep it sleeper, rust and all Guess I could mount them in glovebox.
Can someone send me a link for the hpt Dropbox I've heard about? I think Bill has been mentioned?
Heads back from the shop.
60lb injectors and wideband came in today as well as the phonelic. I installed the Aeromotive pump. The one I got is universal, non venturi. So I'm gonna have to mod the FP canister. Anyone have any tips? Just drill some holes in the bottom?
Install starts Saturday morning. Stoked.
Question: Is the Aeromotive 340 just a rebadged Walbro 255? Sounds ridiculous, but I had someone who considers themselves the voice of 3800 performance tell me this today. I'll let you know who when I have a definitive answer. All the flow testing I've seen shows the 340 spanking the 255 at every level.
This was going to be the weekend, but I just wasn't comfortable putting the heads on with a crack. So...back to the shop they went today. They'll probably pin the crack and I just told them to assemble them for me. I won't have a full weekend to do the install for awhile, so I will probably begin tearing it down mid week and do the install as time permits. No problem for me because I need all the time I can get to learn more about tuning with dhp.
I got the blower back from intense. This will be the last time I ask them for anything, seriously disappointed how he treats locals. ZZP for me. Anyways, everything is painted and ready to roll.
Fuel pump is installed and rewired. Ended up just drilling the canister. Seems I'm losing pressure when the car sits, have to prime the pump longer before it starts. But the 340 is very quiet so I'm happy about that! Decided on the AEM wideband. Need to figure how to get that in to DHP. Ordered a boost gauge today, alternator voltage booster from zzp, and some new ls7 lifters. I really need to get this install on the way because the longer it takes the more crap I buy! So much for a budget build.
Looks like the hard start after sitting overnight is just a byproduct of using the aeromotive pump
6.) I’ve installed my new Aeromotive bypass regulator. Fuel pressure seems to adjust fine and holds great when the engine is running, but when I shut the engine off, pressure drops quickly to zero. Shouldn’t the pressure hold like it did with a stock regulator?
No, Aeromotive EFI bypass regulators may not seal perfectly when the pump is off. They are engineered for the highest possible performance when the engine is running. OEM regulators must hold pressure for 30-minutes after shut-down to pass EPA emissions standards. At Aeromotive we know our customers priority is to have the best possible flow and pressure control when the engine is running and we don’t compromise this standard to force the regulator to seal when the engine is off.
Edit: Just realized this is talking about the Aeromotive regulator. Doh! So, dunno why my pump is leaking down. I'll worry about it after I finish the swap.
So that issue can be checked off the list. Flipping the key twice and waiting a few seconds isn't a problem.
So...I need to eat some humble pie. Whoever said that the black coating on the rotors was actually a coating and not just carbon buildup was absolutely correct. I apologize for my rookie mistake. I pulled another m90 today and its coating was totally intact. My confusion was the way mine was coming off so easily. I've now learned that possibly shooting nitrous through the blower causes the coating to flake off like mine was. So...I got another blower:
Coating intact:
And swapped rotors:
Worse case is I would have lost a lb or two with bare rotors, but why go through all the trouble porting the blower just to make it less efficient? So...if anyone needs a blower with raw rotors, hit me up
Also grabbed the last few tidbits I needed while I was at the yard. L67 map, injector connectors, maf and some vacuums lines. Grabbed a pcm from the Regal I was raping. Not sure if it will work, but Im gonna try to use it as is. Don't even know if my car will start with it in, but half the fun is learning.
Lookin great! I'm not sure if I was the one who said there was no coating on the rotors, but I know I was involved. It happens, lol, at least you were able to get some better rotors in there. It'll help a bit, and those look to be in GREAT shape, especially for a Gen III.
Just looked back and you are the one. Jerk. Being all right and stuff...
Yeah I'm glad I swapped. The rotors are in really good shape. No deep grooves on the edges and zero slop in the bearings. The ones I had would wiggle a little when I turned the pulley, even with a new coupler.
It's been a long strange trip, but I finally have my heads back and I'm happy. The chamber with the crack had new seats installed, need to touch up the machinist ridges a little but its not bad:
And the rest of the seats were cleaned up on a Serdi. And boy are they perty
Much happier with the results using the serdi. The stone job and lapping left wide and rough seats. Now they sit perfect. Here's a little slap test I did with some marker
For my amateur eyes they look good. I'm going to wait to assemble them until I pull my heads off. My car has less miles than the heads I am putting on, so I'm gonna swap springs and keepers. Won't have a lot of time this weekend, baseball games tomorrow, but I think I'll start tearing down tonight. Wish I could have started sooner because now its flippin hot in my shop. Gonna be close to 90 and I'm not acclimated to the heat yet. Not crying, I work outside mostly, but I do need some nice fans for the shop.
Picked up another pcm from the yard, so if I screw one up I have backup. I tried reading a pcm from a 98 regal sc, now I know dhp won't write to them. I'd like to get someone to write me a base tune, just don't have the time I need to figure that out. Then I can use the guides to dial it in. Anyone around here who does that? I sent overkill Will? a pm but haven't heard back. Maybe they don't like emailing custom bins?
