#601
Re: Bandook's 01 Imp, top swap-ified
Donating Users
06-23-2020
Wouldn't it make sense that if my boost was really fluctuating, that I would see some signs in the logs. When i go frame by frame and look at the way the MAF and RPM climb, there is no connection with the jerkiness of the MAP and boost lines. It's a smooth climb. And since I also see my boost gauge in car drop at high rpm, I'm thinking it has to be a vac line issue. Something that a smoke test won't show. Could just be a T connection that is just a little loose that only leaks over like 12 psi. I keep seeing 184 kpa plateaus. I see that number a lot. Yeah, so i'm really really certain this (umpteenth) time that I'm right. lol. I mean, it makes sense, no? Car feels fine. Yup, this has got to be it..... Maybe.... Might just need some zip ties on all the vac line connections.
Top Swapped 01 Imp
#602
Donating Users
06-28-2020
Found a boost leak. It's leaking under supercharger near the throttle body. I let the smoke get a lot thicker before I blew it through and it made it obvious. So now I'm not sure if I'm going to mess with it, Wait till I get the Gen 5 on, or just put a larger goop of rtv on it without the supercharger gasket. When I just installed this gasket I put a smear of rtv on both sides of it. So it's either go big or go home or just wait for the Gen 5. I do feel a bit relieved though because I was beginning to think it was a valve train issue or something.
Top Swapped 01 Imp
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#603
Donating Users
06-28-2020
You probably know that I can't rest until an issue is sorted. So crazy that I get ocd like this about a car I rarely drive. Thinking I'm just gonna put a fat bead of grey or black rtv on it, let it sit a couple hours and torque it down. Don't like not using a proper gasket but I see intercooler guys do it.
Top Swapped 01 Imp
#604
06-28-2020
just rtv is fine, just dont go putting a large bead down. its all gonna squeeze out. couple mm thick smear should do the trick.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#605
Donating Users
06-28-2020
I didn't go crazy. 1/8" bead and cleaned it real well. Gonna let it sit for a couple days. Half shafted the throttle body while it was out. Why not, I guess. Welp, see u in a couple days. Fingers crossed. Test n tune is in two weeks so hope this works.
#606
Donating Users
06-29-2020
Yeah, well....I couldn't wait more than 24hrs. Still wonky. But the car feels as good as it ever has. Oh well. I got to forget about it I guess. Good luck with that though. My brain says "hey! Maybe it's this!!...try this and that!!" Now I'm thinking it might be the map pigtail I got from zzp. I do remember when I first started this build their injector adapters gave me a fit. Had to ditch them.
Top Swapped 01 Imp
#607
Donating Users
Top Swapped 01 Imp
#608
Donating Users
07-02-2020
Look at my picture really close. Tell me what we've all missed. I'm not the only one taking the blame for this. Dagnabbit. I'm such an idiot..
Top Swapped 01 Imp
#609
07-02-2020
Is there a bolt missing at the back edge of the LIM?
#610
Donating Users
07-02-2020
Yup...I've missed it 3 times now. Yeah, I'm embarrassed to admit it, but it is what it is. For some reason I had one of those guide pins in the lim where that bolt goes. I must have stuck it in there last fall and never noticed I had a left over bolt. Yeah, I've had the boost leak since I did the cam. Smh
Top Swapped 01 Imp
#611
07-02-2020
i saw that but figured it was a dowel pin hole maybe. no way you forgot a bolt lol
#612
Donating Users
07-02-2020
Yup, i'm a dummy. Think I'm ready to throw in the towel though, lol. Put another gasket on and it's still leaking. I smoked it real good when the engine was cold, no leaks. But after a run, boost is still same and my wot fuel is leaner than ever. Fuel trims have never been this bad. Thought i didn't connect something but everything looks fine. I'm stumped. Maybe the lim or s/c case is warped now and just won't seal. Probably didn't help driving it with 2 missing bolts. ya think?
Top Swapped 01 Imp
#613
07-02-2020
two missing bolts is a huge vac leak. you'll need to retune the maf for sure.
#614
Donating Users
07-02-2020
Yeah but shouldn't it be showing rich now, if I use the tune that was dialed in with the vac leak? I'm confused now. Doesn't help that I was working in the sun all day. Crap I was light headed the last couple hours.of work, and still had to get this gasket replaced when I got home. I gotta just get this engine crap off my mind. It's a sickness lol. I've got too much stuff to do right.now.
Top Swapped 01 Imp
#615
07-02-2020
with the leaks sealed up, it would be rich now.
#616
Donating Users
07-02-2020
Yeah, ok. Strange. It's worse than ever now. I saw 12.4 at wot. It's never been this lean. Thought it was meth kit not hooked up, but it's working fine. So somehow after all this I end up with a bigger vac leak. Go figure.
Top Swapped 01 Imp
#617
07-02-2020
what jet you using on the meth injector? you got a stock tb or a n*?
#618
Donating Users
07-03-2020
Top Swapped 01 Imp
#619
07-03-2020
id turn the meth off, put the stock maf file back in. lower the timing a lot in your case lol then retune the maf, get it to mid 12's then turn the meth back on. see what the afr is, then adjust the maf as needed.
#620
Donating Users
07-05-2020
Boost is back boys.
Don't know if the picture will upload. So I smoke tested again. Gave it a good soaking. Found a little leak at brake booster. But everything else is solid, no more s/c leak. I took your suggestion Scotty, retuned with wmi off. I'm still seeing fluctuations in boost, but it doesn't fall off as bad. I think I'm possibly getting belt slip still. My theory is when I turn wmi back on, i'll see more fluctuations. It might be putting more of a load on the blower making the belt slip. We'll see. If so it could be my idler. It does seem to move a bit more than i remember. I might post a video to show u. Thanks for the suggestion scottydog!
Edit: Misfires appear to be gone too! #4 was missing the most.
Top Swapped 01 Imp
