Thread: Bandook's 01 Imp, top swap-ified
Page 13 of 32 FirstFirst ... 3111213141523 ... LastLast
Results 241 to 260 of 632
  1. #241 Re: Bandook's 01 Imp, top swap-ified
    Quote Originally Posted by bandook View Post
    OK, I'll use the rest of my tube of copper rtv tonight if I have to, and let it sit till tomorrow. After that its HF welder, and the nightmare welds that follow and will make you taste your stomach contents in the back of your throats.
    dont try to weld it. you'll never get the back side. rtv will work, you dont need a 1/2 a tube either lol run a bead around the lip, smear it. clamp it, done deal.
  2. #242 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    The bigger the blob...and Bob's your uncle...or something like that.
    Top Swapped 01 Imp
  3. #243 Re: Bandook's 01 Imp, top swap-ified
    shluping sloglin with the rtv lol
  4. #244 Re: Bandook's 01 Imp, top swap-ified
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    That tin foil over the coolant temp sensor a special mod you're keeping secret...lol!
  5. #245 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Pffft, I've tried "thin for the win"... Twice. Now its full out warfare. I think its just a crap fit. Its like the angle of the crossover needs tweaked about 3 degrees for it to fit right. I've loosened them and slid them around trying to find that sweet spot but it's just crap no matter where I try to tighten them. Its a small leak, but enough to mess with my head. If this doesn't work I'll probably use these through the winter then look for something better next spring.
    Top Swapped 01 Imp
  6. #246 Re: Bandook's 01 Imp, top swap-ified
    i was letting that go, thinking it was temp heat shield from the leak.
  7. #247 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Quote Originally Posted by 231FUN View Post
    Nah, I had some heat shield foil stuff i had laying around so I stuck it on there. I think there was some factory heatshield material on there before I did the swap.
    Top Swapped 01 Imp
  8. #248 Re: Bandook's 01 Imp, top swap-ified
    that load of rtv and a clamp will seal it up. dont worry bout it no more.
  9. #249 Re: Bandook's 01 Imp, top swap-ified
    Kemmerer, Wyoming
    the last time I messed with my headers, I mucked up the connections with copper rtv, and it worked, at least on the front connection
  10. #250 Re: Bandook's 01 Imp, top swap-ified
    i didn mine all billboost style two times now, no rtv, no leaks. old style sd headers. got em used. and i could see they leaked all over for the last owner. yet they dont leak for me lol
    he also used U clamps for everything. 1/2 the bolts were loose too.
  11. #251 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    OK I'll bite, what's billboost style? Install headers and downpipe on engine, on the stand, ...and reassemble car around them?
    Top Swapped 01 Imp
  12. #252 Re: Bandook's 01 Imp, top swap-ified
    its his how to install headers thread.
  13. #253 Re: Bandook's 01 Imp, top swap-ified
    Kemmerer, Wyoming
    I'm going to fix the exhaust header leaks one more time, and need them to last 3 months. I plan on doing the turbo swap by then. might have a set of headers for sale in 4 months.
  14. #254 Re: Bandook's 01 Imp, top swap-ified
  15. #255 Re: Bandook's 01 Imp, top swap-ified
    Billboost is.. Sell all Wbodys and buy a Audi and not worry about leaky SD headers anymore.
    04 Comp G.
  16. #256 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Just read it. I basically did the same but didn't use a rubber mallet. I just banged the crossover around with the heal of my hand and coerced it into what seemed like its natural resting place. Dunno though, I still say the angle is off a couple degrees.
    Top Swapped 01 Imp
  17. #257 Re: Bandook's 01 Imp, top swap-ified
    iirc it says to leave the rear header loose too, then whack the pipe to get it lined up, then tigten up all the headers bolts. how mine went down.
    only my cross over pipe has no fight left in it lol its been handled so many times now it knows where it wants to be.
  18. #258 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    No it says tighten rear header first, and tap crossover while tightening front header. Then tighten clamps. The crossover moves freely with rear header bolted down, until front is tight then its locked in place.
    Top Swapped 01 Imp
  19. #259 Re: Bandook's 01 Imp, top swap-ified
    either way lol
  20. #260 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Don't make me get my welder out... I ain't scared.
    Top Swapped 01 Imp
  1. Couple questions regarding build in progress
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2013, 11:03 AM
  2. Top swap Progress
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-15-2012, 05:55 PM
  3. Top Swap progress
    Last Post: 09-14-2012, 07:04 PM
  4. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  5. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
