Thread: 2000 turbo regal v.notSnowflake *now with more flames*
Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
Results 221 to 240 of 353
  1. #221 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    slowly getting all the little things sorted out and setup
    looks good, still need moar low'n but chicago streets suck enough that i prefer the ground height
    ~James~ Psychotic Gearhead
  2. #222 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    oh, good news, ive had several hard as hell highway-bridge-highway transitions that have slammed hard enough that im damned certain we've hit the koni bumps, they looked fine as of last night, along with the hats, driving to cars and coffee this mornin.
    i feel so bad ive put more miles on it than kevin, though he did get to hear it drive from his TDI, gave him a 40% throttle, whistling jet catching up to him from behind, didnt even go into boost (hovering right near 100kpa).
    he reminded me how quiet the car is, i totally forgot since the inside sounds like a herd of 600 ponies stampeding
  3. #223 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    did some fuel cannister work to reduce the tendency for air bubbles to get recirculated.
    finished product uses the pump well as a drain well that lets the bubbles spill over the top of the can and allow mostly liquid gas to drain into the lower can/main reservoir through the drain holes in the W255 pump holder
    kept the venturi, used spring and disc from spare canister rollover/vent valve, disc snaps right into top of venturi bypass float well, spring biases the float into the venturi functioning all the time, and not just when the canister is at 1/2 full or below.
    in cannister sock ripped apart, inner support modified into a "pink sock" pump inlet strainer. external venturi sock is intact
    has really cut down on the bubble recirculation, even as low as a 1/4 tank.
    return tube cut and bent to shoot at pump well when at installed height.
    before final assembly (pump inlet plugged to keep debris out till install)
    here you can see the rollover spring/disc shoved into the venturi float well. also note pump strainer
  4. #224 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    This thing never fails to blow my mind
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  5. #225 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    meh
    i try
    just got back the trans spacers, probably sell the 3/8ths one now that i made the 1"
    blue came out perfect, add some strength to the case and i can ditch the modified/fixed zzp pan for a modified stock pan
  6. #226 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Arizona
    Good, you selling me a copy?
  7. #227 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    I only have that 3/8th inch spacer that im getting rid of, the 1" spacer was quite difficult to get a piece of pressed 6061 plate big enough
    I was going to put the 3/8ths on top of the modified zzp pan but im going with the 1" and a modified OEM pan.
    whenever I finish ill have the zzp pan and the 3/8ths to unload
  8. #228 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    May 2008
    Schuyler, NE
    What are you going to use to extend the pickup down to the pan?
  9. #229 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    im making a filterless sump tube and pan baffles, trans will use a PF52 inline filter on the cooler/lube circuit, that way we only need one part number filter
  10. #230 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    the 3/8ths was just figured on not popping the filter all the way up...but with the 1"....might as well go insane
  11. #231 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    May 2008
    Schuyler, NE
    I think you can buy an extension from jegs that works. Snowflake did it on his car.
  12. #232 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    OEM filter sucks
  13. #233 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    May 2008
    Schuyler, NE
  14. #234 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    it's cheap and fairly easy to replace. the problem is is that it's too restrictive 4 fluid that is mostly clean.
    but with putting the filter on the outlet of the pump on the cooler circuit where it supplies the lubrication points is desirable
  15. #235 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Feb 2013
    Missouri
    I just started my transmission build, I'd be interested to see how you pull it off. Might even pick up that spacer depending on the $ and what not.
  16. #236 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    i had a swinging pickup idea earlier
  17. #237 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Arizona
    Quote Originally Posted by Turbocharged400sbc View Post
    Use the wix filter instead it's a 1515 iirc. Couple capicty and flows more Than the Fram version
  18. #238 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
  19. #239 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    ^^ That just made my day...
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  20. #240 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    Boost controllers all hooked up.
    Ready for 7 stages of boosting beoch
  1. Kim's Regal Turbo - BOV fun on page 4
    By blueguy in forum Members Rides
    Last Post: 06-24-2014, 03:04 PM
  2. 2000 Turbo Regal
    By SnowFlake in forum Members Rides
    Last Post: 06-23-2014, 05:27 PM
  3. Turbo Regal vs Turbo LSx Trans AM
    By SnowFlake in forum Track Sessions and Kills
    Last Post: 06-15-2014, 12:17 AM
  4. 98 Regal GS Turbo
    By Speeder in forum For Sale - Vehicles
    Last Post: 05-03-2014, 03:37 PM
  5. Turbo'ed Monte Carlo up in flames **(Pics)**
    By bbptech in forum Off Topic Discussion
    Last Post: 11-12-2009, 05:32 PM
