Thread: 2000 turbo regal v.notSnowflake *now with more flames*
Page 2 of 18 FirstFirst 123412 ... LastLast
Results 21 to 40 of 353
  1. #21 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    Mmmmmmm racecar
    ~James~ Psychotic Gearhead
  2. #22 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Aug 2013
    McDonald PA
    Mmmmm pics with them on!!
  3. #23 Re: 2000 turbo regal v.notSnowflake *now with more flames*
  4. #24 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Banned
    CT
    racekars have to raise the rear
  5. #25 Re: 2000 turbo regal v.notSnowflake *now with more flames*
  6. #26 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    on the car they came off of the front were all the way up while the rears were two inches from the top
  7. #27 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    got some test pieces cut from heatsink extrusion for the ICM stacking...should work great
  8. #28 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    got a bit farther with the ICM stacking project.
    made the plates and now the pins for the top ICM coil taps.
    enjoy
  9. #29 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Now I'm a bit confused. Why 2 ICM's?
  10. #30 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Better thread is on thechicagogarage.com
  11. #31 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    here is a video with and without the second ignition control module you can clearly see the sparks intensity change.
    http://youtu.be/7nx7l9lG4Jg
  12. #32 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Hey..I'm not unwilling to read. I already read up, watched it.. cool stuff.
  13. #33 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    i like the idea of stacking 2-3 and running 6 "dumb" lsx style Coil per plug units.
    full firing voltage at both banks and maybe we can run full boost at .035 gap
  14. #34 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    the transmission is mostly back together.... I cannot find my inch pound torque wrench but I'm working on that.
    picked up a nice little 8 point cage....
  15. #35 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Bunnell, FL
    pics?
    details?
    where?
    I'm a Sex Offender
  16. #36 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    1st gen W/GP jegs kit
  17. #37 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    traded the 3.29 FDR 1" GMR gears for Matt m's old set of 2.93 FDR gears
    also doing my own version of the "Norris" brace
    template
    first test piece...it transfers the twisting forces to the reverse band pin boss and to the center channel plate support through preloadable bolts.
    and on an update with the ICM stacking test subject...Cody's full boogie Nitrous Riviera...so far over 1500miles with it running both ICM's with stock L67 coils hopefully before the year is out he will see if he can run a larger gap without blowing out the spark...so far there is quite a large difference between the arc with 1 vs 2 ICM's just watching the arc across the coils secondary terminals...so id bet he will no longer have ignition issues.
    some pics of his setup
    here you can see his dual relay system for IGN power.
    oem icm power feed just activates the first relay to feed power direct from the alternator to the ICM/Injectors (removing all the OEM voltage drop/resistance), the second relay is for switching on the 2nd ICM at 2psi...however due to a bad hobbs switch he's been running it on both constantly with no issues...the heatsinks seem to do a fine job rejecting the heat.
    i just need to start cutting out the heatsink spacers and the TR's setup will be ready...to let us run bigger than .030 gap at 22psi and clean up the ****ty idle from the smaller than .045 gap it likes for a smooth idle...
  18. #38 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Feb 2013
    Missouri
    Awesome build. I love the ICMs and such. I wanna see how this Norris brace works out.
  19. #39 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    hangover park IL
    Dave's brace is far stiffer and supported better. ..but we just need to make sure we're good to about 700 wheel horsepower.....I'm just hillbillying it up
  20. #40 Re: 2000 turbo regal v.notSnowflake *now with more flames*
    Feb 2013
    Missouri
    Do you have pic or link of the finished product? Looks intriguing
  1. Kim's Regal Turbo - BOV fun on page 4
    By blueguy in forum Members Rides
    Last Post: 06-24-2014, 03:04 PM
  2. 2000 Turbo Regal
    By SnowFlake in forum Members Rides
    Last Post: 06-23-2014, 05:27 PM
  3. Turbo Regal vs Turbo LSx Trans AM
    By SnowFlake in forum Track Sessions and Kills
    Last Post: 06-15-2014, 12:17 AM
  4. 98 Regal GS Turbo
    By Speeder in forum For Sale - Vehicles
    Last Post: 05-03-2014, 03:37 PM
  5. Turbo'ed Monte Carlo up in flames **(Pics)**
    By bbptech in forum Off Topic Discussion
    Last Post: 11-12-2009, 05:32 PM
