because I can?
Its going to go over $1500, which is more than I would go.
I would just repaint it, restore the interior, fix anything else and just cruise with it. No mods just cruisin'
I am on the hunt for one of these 99 Turbos, Someday I will nab one. They really top out at around $7,500 for a pristine low mileage one. So a fun little classic car for not too much coin.
So I did the sound deadening...no rattles in that car anymore. Sold off what I had left. Yippie.
Things happening this weekend:
-Steam bath the engine bay (top to bottom)
-Gold foil heat wrap delivery pipe
-Clean throttle body
-Install painted turbo heat shield
-Polish shiny parts
-Front tie rods
-Onstar antenna replacement
Other things on the plate to do:
-Replace driver's seat bracket
-Install Kenwood DDX5901HD radio
-Fix recircualtion motor arm for HVAC
-Finish projector retrofit
-Replace passenger headlight washer
-Track down resuspension clunk (50/50 on whether the exhaust is hitting or something in the suspension)
-Hirsch Pedals
-Lower control arms with new bushings and balljoints
I have a water pump and alternator on the shelf for the day those fail...and when they do...I've replaced everything else in the engine bay.
June 1st the car goes into an auto body shop and comes out 100%...RUST FREE and the back half of the car repainted. I'm considering repainting the front half of the car next year.
Pictures:
I didn't do the sludge. I only did the front doors so far, rear doors will happen in time; upper part of the dash, inside and bottom part of the dash will happen when I rip it out again; sections of the roof, the door trim pieces were done; the rear deck and rear wheel wells were done. I really just wanted to kill rattles and I did. I went to do the floor and the sound insulation and deadening is a bit excessive on Saab's part already, in fact if I added the Luxury Liner Pro...I wouldn't have been able to put the carpet back or anything else for that matter. Car is pretty decent at 75mph on the highway. I have no exhaust drone, never have. I can only hear my exhaust if I'm on it and above 3,500 rpm.
Good stuff though, that **** sticks to anything no problem.
FWIW The sludge is Spectrum with activator added in. IIRC you can spray Spectrum to the under body so and it protects the surface as well as deadens sound.
Read this and laughed
Saabs are not as reliable as Audis. They spend more time in the repair shop than its German competitor. And Audi has a higher resale value than Saab.
So Phase 1 of this project completes soon, some big things happen next week and on July 4th weekend I finish Phase 1.
Phase 2 begins this winter....and then Phase 3.
Hint, it involves an LSD and GTX2971R
Bill wants more details
Finish Phase 1:
-Car is having the hood, front and rear bumpers repainted and rust eliminated and rear quarters repainted.
-Underside of the car soda blasted and wheel wells sealed (eventually time table not set)
-Redo windshield tint
-Kenwood DDX372 (a little cheaper than the DDX5901HD)
-Replace Driver's seat bracket
-Fix HVAC recircualtion arm
-Sound deaden dash
-New OEM cabin filter (MANN ones don't fit right)
-Finish up projector retrofit
-Detail engine bay
-Custom Steering wheel
-Replace driver's door to eliminate rust
-Chase down rear suspension clunk
-Replace headlight washer
Phase 2 (winter 2015/16 into summer):
-Hirsch Pedals (or the replicas)
-Short throw shifter
-OEM Lower control arms with new rubbers and ball joints
-Cobalt SS Brembo caliper and stainless steel lines (all 4 calipers powder coated...probably Orange)
Phase 3 (gather parts in summer 2016/work winter of 2016/17):
-Built motor (B234 block, B235 Crank & Rods, new bearings (maybe uprated), balance shaft delete, forged pistons (overbore 1.0mm), heavy ported & polished heads, B235R Sodium filled valves, T5 cams, ported or tubular exhaust manifold, some intake work, custom phenolic spacers)
-A good fuel pump and injectors for both 93 and E85
-GTX2971R
-3" Catback
-Things painted and powder/ceramic coated
-Rebuilt Transmission with LSD
-SPEC stage 3+ clutch
-Big front mount intercooler
Phase 4 (summer 2017):
-Enkei RPF1 wheels
-Reupholster interior with black leather, black carpet, Hirsch replica the seats
There you happy Bill
Or...I could leave it the **** alone because right now the thing hums along great and I have no reason to do the engine build. But if I have the time and ability to get it done, I would like to.
