Well i have been on here a few years but have not made a members ride page until now lol. So heres my story and process from the start to where i have her now!
Bought the car back in 9/08, it is a 2004 Galaxy Silver GT2 and was bone stock when purchased. It had roughly 65K on the odometer and now i'm at about 140K and still going strong. When i first got into modding the car i started out with the typical N/A upgrades, Plog, ER Rockers, CAI, Thermostat, Plugs/wires, downpipe..ect and it net me no where near what i was expecting for dropping the amount of money i did... so decided to start the Top-swap( back in 2010) adventure and havent looked back since! I gathered all the parts and so began the quest to bring the car to life.
So heres my mod list:
ENGINE:
-Top-swaped L26
-Polished Gen V w/ ZZP hub and 3.0 pulley
-Mild P&P Heads with 5 Angle valve job
-ARP head bolts
-ZZP 1.9 Rockers
-LS6 90# Springs w/ comp cams retainers..ect
-42.5lb Injectors
-ZZP Fuel Rails
-Sseilmnop 2" Phenolic Intercooler
-ZZP Stage 3 HE
-Bosch Pump
-Cobra Reservior
- LQ4 Maf
-K&N intake
-MSD Ignition Coils
-PRJ Plug Wires
-Autolite 103's
-Optima Yellow Top
-180 T-Stat
-Alternator re-wire
-Fuel pump re-wire
-Overkill PCM (also a custom in car tune)
-SLP Smooth Bellow
-Custom catch can setup
EXHAUST:
-Pacesetter Headers(Titanium wraped)
-Full 3" custom exhaust(Magnaflow Cat)
-37" Red Cherry Bomb as Resonator
-Magnaflow mufflers
-SPO dual tips
SYSTEM:
-Pioneer Headunit
-Rockford Fosgate Power 6X9's
-Rockford Fosgate Power 6 1/2's
-Rockford Fosgate T1T tweeters
-Rockford Fosgate Power 3" Center Channel
-Rockford Fosgate HE2 12" Subs(x2)
-Rockford Fosgate Punch 4 Channel amp (800W)
-Rockford Fosgate Punch 2 Channel Amp (600W)
SUSPENSION:
-Air Bags over struts
-Accuair E-Level Management System
-Yor-Lok SS compression fittings
-SS polished hard lines
-Accuair 5 gallon tank
-Viair 444c compressor
-Accuair Exo mounts
-Arraut Motorsports rear swaybar mounts
-Dorman 33mm Front sway bar
-ZZP Front and Rear STB
-GMPP Rear Sway Bar
-GMPP Rear Trailing Ams
-BMR Front and Rear Lateral Arms
-Full Moog bushings, ball joints, tie rods, sway bar links...ect.
-ZZP Red Poly Trans Mount
-ZZP Poly Engine Mount
-ZZP Red Poly Dogbone Mounts(square and round)
-ZZP polished engine braces
-ZZP Polished Dogbones
BRAKES/WHEELS:
-CTS-V Front Calipers
-GT500 14" Front Rotors
-ZZP Stainless Lines
-Hawk HPS pads
-Powerstop Drilled and Slotted Rear Rotors
-Powerstop Ceramic pads
-18" Konig Backbones
-245/45/18 Hankook Ventus V12 EVO
EXTERIOR:
-SPO Spoiler (black)
-HD lip upgrade
-Black SPO grilles
-20% tint
-LED smoked tail lights
-Black reverse light bar
-Inferno front facia
-Inferno Hood
-Weathertech window deflectors (dark tint)
-Custom Projector Rerto-fit
---- Morimoto Mini H1's
---- Gatling Gun shrouds(paint matched)
---- 80mm Red XbaLEDs
---- 70mm While XbaLEDs
---- 6k Morimoto bulbs
---- 55w Morimoto ballasts
-Stage 2 LED Sidemarkers
-Stage 3 LED reverse lights
-Stage 2 LED licence plate lights
INTERIOR:
-Red Suede Door Panels
-Silver Trim Pieces
-ZZP Triple Gauge Pod
-Aeroforce Scan Gauge
-Autometer Electric Oil pressure
-Autometer Wideband
-Autometer Boost Gauge
-Stage 3 LED Lights(dome, footwell, map)
Heres what it looked like when i first started back in 09
