We pulled the motor in March with plans of a simple cam and headers install with a smaller pulley and a good tune... however after pulling the cam it looked like the lower intake had leaked coolant on the cam in the past causing fairly significant cam bearing wear. So we ordered new bearings and ARP bolts and off to the machine shop went the block, pistons, rods, crank, flex plate balancer etc.... Along with the normal block and piston reconditioning and new bearing install we had the heads ported, balance shaft oil hole plugged and the crank balanced. All of this was done at Automotive machine in Fraser MI. They do great work and are good guys however they had a bunch of motors in process and it took about 4 weeks to get our motor back. New parts include oil pan, oil pump, water pump, cam sensor, rollmaster timing chain. We went with an Xtreme energy cam, 105 springs and SLP ceramic headers. After a week or so of cleaning, painting an putting the motor together it is going back into the cradle tonight! We are planning a trip to Intense shortly for a smaller pulley (prolly a 3.2 or 3.1) and a dyno tune. Next winter we will work on the top half of the motor. We are thinking about going with a Gen 5 SC, full sized intercooler along with 60lb. injectors and some sweet looking fuel rails. We will also beef up the trans next winter. This is how the motor will look until next spring....
