Thread: Budget Comp G. 2.5" pulley = no belt slip
Page 3 of 89 FirstFirst 123451353 ... LastLast
Results 41 to 60 of 1773
  1. #41 Re: Budget 04 comp g running total $2200
    I put lucas in it at the oil change on saturday.
  2. #42 Re: Budget 04 comp g running total $2200
    Oct 2011
    Puyallup WA
    Must have been a long time since the plugs where changed!
    08 G8 GT - exhaust Tune
  3. #43 Re: Budget 04 comp g running total $2200
    I still have to change the others. I'm hoping I can flush the motor out and salvage it.
  4. #44 Re: Budget 04 comp g running total $2200
    SE Level Member Sevex's Avatar
    Aug 2012
    Utah
    It almost looks like it had something go through that cylinder? hard to tell from the picture but the only time i have ever seen a plug like that is when something entered the cylinder ( could be pieces of piston too) or detonation so bad that it melted the ground strap.
    04 CompG, 1.9 rr, 90# springs, modded SD headers, 42.5#.... intercooler/3.0 mps coming soon.
  5. #45 Re: Budget 04 comp g running total $2200
    I won't be surprised if it had 87 octane in it. It probably had a hell of a lot of kr
  6. #46 Re: Budget 04 comp g running total $2200
    Jul 2012
    Chicago
    Hopefully it doesn't bite the dust. God damn that thing was dirty under the hood. Best of luck to ya.
    -Carl
  7. #47 Re: Budget 04 comp g running total $2200
    if the low oil pressure light came on it's only a matter of time. you just did an oil change. that oil light comes on at 5psi, which is way way low.
    get ready to buy a short block.
  8. #48 Re: Budget 04 comp g running total $2200
    I have one laying in the garage. I'm going to try an engine flush tonight I figure it can't hurt. It isn't knocking yet.
  9. #49 Re: Budget 04 comp g running total $2200
    What Eastwood said.
    Anything less than 10~ and it's only a matter of time...really.
    Suxors.
    Maybe pull the front cover and blast out the oil passages and run seafoam through it like whoeveritis said earlier? Doubt it would help much...but I know after I had a motor let go, my pump gears were trashed in the cover. I replaced them when we put the car back together and had TONS and I mean TONS of pressure...like it never went under 40~ even warm, lol.
  10. #50 Re: Budget 04 comp g running total $2200
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Quote Originally Posted by wa04compg View Post
    Try running a can of seafoam through it might help clean it up alot...did you get a chance to check compression? How are the plugs?
    i run a can of sea foam through the gas every 2k miles keeps her purring nice and happy
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  11. #51 Re: Budget 04 comp g running total $2200
    Quote Originally Posted by travisgt2 View Post
    Overkill, brew.
  12. #52 Re: Budget 04 comp g running total $2200
    Changed the pcv valve and the ticking noise went away as it was running I looked under the car and the oil pressure switch was broken and pissing oil out. That's probably the cause of the low oil pressure light. Hope a new oil pressure switch will take care of this all.
  13. #53 Re: Budget 04 comp g running total $2200
    Sep 2011
    Copperas Cove, TEXAS
    Keeping hopes up for Dan the family man to get hooked up with a car that just needed a little TLC and not a motor.
  14. #54 Re: Budget 04 comp g running total $2200
    Got the oil pressure sending unit changed today. Also changed all the plugs. One rear one was finger tight and the end was gone but not misfiring lol. It still is making a ticking noise I might pull the rear valve cover and see where it's coming from I'm thinking chipped piston but I don't really know. I can hear in in the rear valve cover pretty bad in the #2 cylinder.
  15. #55 Re: Budget 04 comp g running total $2200
    Sep 2011
    Dan, can you swap out a chipped piston or do you have to rebuild?
  16. #56 Re: Budget 04 comp g running total $2200
    He could take the chance and just put a piston in and new bearing and see how long it lasts. I know sandman did that and his lasted for a pretty long time before he just swapped blocks.
  17. #57 Re: Budget 04 comp g running total $2200
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    keep the info coming!!!!!
  18. #58 Re: Budget 04 comp g running total $2200
    I probably won't get to look into any further until saturday. I drove it down the road yesterday and it seemed to shift good and everything. When I got it back home the tick seemed quieter. I'll probably try driving it around town today.
  19. #59 Re: Budget 04 comp g running total $2200
    Nov 2012
    Madison
    So other than the tick tick noise everything is A-OK, no codes and somewhat tip-top? Is it road worthy or like way questionable?
    Old owners probably took care of engine the same way as the body and interior as cheaply as possible.....
    Good luck, sounds like almost a 180 on how it WAS running
  20. #60 Re: Budget 04 comp g running total $2200
    Runs great other than the tapping. I'll pull the valve cover Saturday and see what I find. Going to get a new battery for it today.
  1. A little burn out . lame but you should check it out.
    By drewprix86 in forum Off Topic Discussion
    Last Post: 01-14-2011, 09:39 AM
  2. Budget door comp set
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2010, 07:42 PM
  3. 4 door is lame! Seriously WTF?!?!?!
    By telkel2399 in forum The Rant Forum
    Last Post: 12-07-2009, 03:58 PM
  4. How lame is this thing
    Last Post: 02-17-2009, 12:24 PM
  5. 04's are the same... lame!
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 10:46 PM
