Thread: Starting to build up the intrigue, finally
Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 273
  1. #41 Re: Starting to build up the intrigue, finally
    Quote Originally Posted by intrigue98 View Post
    Bill and I made some progress tonight. Aside from cleaning up/organizing the garage a bit, we:
    - installed valve covers for good
    Wait..I'm confused. I stood around and didn't even put gloves on, there was no help from me. I was just...there.
    and... the second part, about putting the covers on for good,..... HI MAX!
  2. #42 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    haha
    1998 Intrigue - Parted out
    2008 G8 GT - Heavily modded
    2016 WRX STi Limited - Bolt-ons
  3. #43 Re: Starting to build up the intrigue, finally
    had to do it.
  4. #44 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Alright guys, tonight Bill and I dove into the transmission. Bill thought we should've gotten further within the 1.5 hrs we worked but I think we did okay. Today we:
    - removed all parts within the case
    - removed filter/accumulator
    - installed 3rd gear Zpak (added additional wave plate, yeah, no slop there lol)
    - Raybestos Stage 1 clutches for input (added additional steel plate, no slop) and 2nd gear (added additional friction plate)
    - swapped over to the newer ratcheting 3rd gear sprag
    Parts I learned that I now need to order/planned to order: Transgo shift kit, high energy green bands for forward, reverse, and manual 1-2, new 4th gear clutches/steels, filter, and maybe a few other things I forgot.
    When I tore down the trans I shook the clutch packs. There was a lot of slop. 2nd gear was pretty well shot. I managed to do that kind of damage in about 5-10k miles when it was in the GTP haha. The Raybestos Stage 1 clutches are the best we can get right now for our 4t65e's and of course the 3rd gear Zpak (nice knowing I have a spare). Looking forward to nice firm shifts and breaking the tires loose on command.
    I'm taking Tuesday-Sunday off so project intrigue is happening next week for sure. Prior to that, Kooks Longtubes are making there way into the G8 this weekend
  5. #45 Re: Starting to build up the intrigue, finally
    Yep...Max kept slowing down becaue he wanted to know the part names and compare things to new parts. Geez, can you believe this guy? A straight forward case unloading is maybe 30 minutes. Redoing the clutches another 30 minutes. I figure we blew an additional 30 minutes talking and looking at the chunks missing from his 2nd clutches.
    Max, we need more pictures of stuff. Like the comparision in size of input to 3rd to 2nd and 4th. 2nd is by far the beefiest pack in there and that was the pack that you chose to beat on. I pity a transmission under your foot. I think your foot learned from my foot.
    Additional part: Diff lube tube retainer
    I'll toss this here for your lunch time reading pleasure.
    Trasmision Automatic A Buick-Oldmobile 4T65E
  6. #46 Re: Starting to build up the intrigue, finally
    PS.. 8 foot car work table was one of those, great tool purchases. And it doubles as a pong table.
  7. #47 Re: Starting to build up the intrigue, finally
    Love ping pong.
  8. #48 Re: Starting to build up the intrigue, finally
    Beer pong table.
  9. #49 Re: Starting to build up the intrigue, finally
    Change Glen to Bill....
    GTX Level Member crbquist's Avatar
    Massachusetts
    Lookin good so far Max! I'll have to swing by one of the nights you're there to check it out! I'm right down the street a few days a week. Good work!
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  11. #51 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Yeah Chris, I'll let you know when ill be over bills. Im off Tuesday thru the weekend and plan to bring the intrigue in the garage first thing Tuesday. Finished up the Kooks longtubes and high flow cats today on the G8. I was so anxious that i stayed up late and dialed in the tune. AFR is spot on, i can add maybe 1-2 degrees more of timing. She pulls nice now
    Ill post some pictures up later today.
    Massachusetts
    Nice! Yeah that thing must move good.
  13. #53 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Didn't finish it all this past week but the trans was rebuilt, AN fuel lines installed, air conditioning system replaced, wideband installed, headers welded, gen v painted, and a nice L32/built trans sitting in the engine bay. Just the tedious detail work remaining!
  14. #54 Re: Starting to build up the intrigue, finally
    What Max is trying to say is ... there's a lot of work when you are going from stock to mildly modded.
    We prepped, prepped and prepped some more before the car came in the garage.
    Drained oil/coolant
    Pulled axles
    Removed exhuast before catback
    Unhooked electrical
    Unhooked trans lines
    Removed motor/trans complete
    Removed radiator, found lower trans line was going to leak soon
    Removed condensor
    New condensor, new orifice tube, new accumulator/dryer, and new seals on whole ac system.
    Replaced LCA's
    New radiator (the big one)
    Flipped sway bar
    Modified motor mount bucket for aluminum pan/mount
    Ran wiring for wide band
    Cut fuel lines and put on new AN lines
    Moved EWP to new motor
    Dropped in new motor/trans (motor is only built to LIM/valve covers)
    New axles
    New endlinks
    New AC compressor
    Rear header bolted to engine loosely
    Trans shifter and electrical reconnected
    All lower engine electrical reconnected: VSS, Oil pressure, knock sensor, starter, ground, oil level
    A good day of work for sure. Now it's pull the bumper cover and run IC/trans cooler stuff, Add to the engine harness for the map location move and BCS, finish building the motor.
    I took one picture.
  15. #55 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Yeah, that sums it up well. Haha. Now seeing that list, I feel pretty good on the progress. Looking fwd to getting it running this week.
  16. #56 Re: Starting to build up the intrigue, finally
    Without the list, it sounds like we are slow. I wanted to clarify, I wasn't the one that built a seat inside the engine bay. (pretty good idea since you were in there that long)
  17. #57 Re: Starting to build up the intrigue, finally
    Tossing this out there
    Last night:
    Added BCS wire at PCM for the postiioning of a 98 Regal. Clear connector Pin 77
    Tied that into circuit 339 for power as it would be from the factory. (339 power evap as well. Moved MAP (L36 connector for L32 map sensor) and evap to the back of the motor. Extended a remote start wire down the harness and over by the pcm for a clean look.
  18. #58 Re: Starting to build up the intrigue, finally
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Just a couple wires there.
  19. #59 Re: Starting to build up the intrigue, finally
    The stuff on the left is the loose wiring I grabbed from a spare harness. There's an evap and about 4 feet of it's wiring, connector for BCS and 4 feet of wiring, plus lengths of the same color wires that the MAP uses to extend it out. Overall the first pic was to scare Max.
  20. #60 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Yeah, he did a good job. I was wondering why my harness appeared to be everywhere. Game plan for tonight is to make some progress on exhaust, more wiring, paint some stuff, remove bumper cover, and start mounting the IC pump, heat exchanger, and desert fox transmission cooler.
  1. 00' Grand Prix GTP (Build starting)
    By Stinkygrub in forum Members Rides
    Last Post: 04-09-2012, 10:48 AM
  2. trouble starting after topswap/build
    By MrClean in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 11:08 PM
  3. Starting the new build soon:)
    By bballa0740 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 09:34 PM
  4. Carbon Build up / hard starting
    By john breit in forum General Tech Discussion
    Last Post: 03-07-2011, 02:46 PM
