Thread: Starting to build up the intrigue, finally
Page 2 of 14 FirstFirst 123412 ... LastLast
Results 21 to 40 of 273
  1. #21 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Thanks! Heads should be done early next week. This Sunday the front bumper cover will be coming off so I can mount the FMHE and trans cooler.
    1998 Intrigue - Parted out
    2008 G8 GT - Heavily modded
    2016 WRX STi Limited - Bolt-ons
  2. #22 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Got the heads back from the machine shop this past Saturday. I think he did a good job. Since the main concern with porting heads is always the exhaust I went a slightly different route and had him open the sides all the way to the gasket, kept the floor the same, and opened the roof almost all the way. Now they are basically a D-shape. I think these should flow nice. No flow bench to verify but we'll see how she does on the dyno once put together.
    L32 heads: decked the surface for flatness, 3-angle valve job, tank, paint, check for cracks, replaced two valve seats (found 1 crack in between the stock intake/exhaust valve seats), gasket match port job on the intake runners, ported the exhaust. Kept the combustion chambers and bowls stock. I didn't feel the need to 1) pay someone 400-500 extra to do the work 2) too lazy to spend the 20+ hrs to do it myself. It's just the daily beater lol.
    - stock valves
    - milled for .650" clearance
    - crow cams 130lb springs
    - comp cams titanium retainers
    - comp cams valve locks
    - ported intake, exhaust, valve job
    Scribed the stock head with exhaust manifold gasket:
    After porting:
    More pictures:
    Finished head vs. stock head
    Not as much done on the intake side as I'd like, but, its smooth all the way in, just not opened up as much as I was hoping for...
    Last edited by intrigue98; 10-25-2012 at 11:14 PM. Reason: added more pictures of the heads (intake and combustion chamber)
    Quincy, Mass
    Those look really nice!
    No more GP 04 Impala SS Indy:
  4. #24 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Installed the heads last night, plan on wrenching more tonight. Will update later with more pictures.
  5. #25 Re: Starting to build up the intrigue, finally
    I was there..this actually happened!
  6. #26 Re: Starting to build up the intrigue, finally
    Bill you need a webcam in your garage...so I can watch you.
  7. #27 Re: Starting to build up the intrigue, finally
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    I cant wait to see some numbers for your build Max! Should be pretty stout. And that head porting looks excellent!!!
  8. #28 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Thanks Dan!
    Here is my update as promised lol. Actually did pretty good tonight. Bill and Swiggles were supervising, with beers in hand
    With installing the heads last night, tonight I:
    - cleaned, prepped, and painted my valve covers a gloss wrinkle black (VHT paint from Advance Auto for those wondering)
    - cleaned LIM
    - installed stock L32 lifters (only 55k miles)
    - installed LIM gaskets and LIM (not sure if you notice, but its been ported and the whole inside of the LIM is smoothed and polished)
    - installed INTENSE oil restricted chrome moly pushrods (7.3" length specifically for the Yella Terra rockers)
    - installed Yella Terra 1.8 Rockers
    I put the valve covers on just to snap some pictures, but, they'll need to dry thoroughly before I put the grommets in and install them. When I came home, I also got my polished/billet belt wrap kit. It'll look nice under the hood.
    Anyways, here are some pictures:
    Some pictures with the valve covers
    Someone dropped by tonight... had to snap some pictures for Swiggles
  9. #29 Re: Starting to build up the intrigue, finally
    Damn it...Bill you didn't tell me there was a party last night.
    Looks good Max!
    Quincy, Mass
    Just an FYI, the belt kits don't usually work with the Bonnie bracket if you are going that route. I ended up using a bigger idler pulley on the Bonnie bracket for more wrap, I believe it was from a dodge ram.
  11. #31 Re: Starting to build up the intrigue, finally
    Bettendorf, IA
    Looks great, how does it run?
  12. #32 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    If you're referring to the turbo car, its not mine.... my motor is not running yet.
    Quote Originally Posted by Swiggles View Post
    I'm using the stock cast iron coil pack bracket with a Smoothflow Belt Wrap Kit.
    Quincy, Mass
    The turbo motor in the pic is mine, it's running great btw, just need max to tune it
    Ok good I really like the smooth flow kit. If your interested I have some 8rib mps pulleys from him too. I don't think I have the hub still but ill check.
  14. #34 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Thanks Swiggs but I have all the pullies I'll need: a 2.9" to dial her in and a 2.7" if the dyno tells me she can handle more boost lol.
  15. #35 Re: Starting to build up the intrigue, finally
    Swiggs...wanna race my Saab :LOL:
  16. #36 Re: Starting to build up the intrigue, finally
    When is the motor going in? I want to come down for that!
  17. #37 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Quote Originally Posted by Drunkie View Post
    At the rate I'm going, I think the motor will be complete (minus IC and Supercharger, will wait until its in the car for that stuff) this week so then I can put the transmission on the stand to begin its teardown. I'd like to shoot for Thanksgiving weekend (if Bill is around and willing ). I have that Thursday-Sunday off, and may take a couple more days off if all works out.
    It really boils down to me wanting to put the G8 away for the winter asap, so I'm going to do my best to hold to that time lol. I don't want to get stuck or expose the G8 in any kind of salt/snowy weather.
  18. #38 Re: Starting to build up the intrigue, finally
    Damn it...Bill you didn't tell me there was a party last night.!
    Would have let you know.. You had already bitached out on the meet we were going to ....
    See above..is your Saab going to be running? lol
  19. #39 Re: Starting to build up the intrigue, finally
    Donating Users
    MA
    Bill and I made some progress tonight. Aside from cleaning up/organizing the garage a bit, we:
    - installed valve covers for good
    - installed ZZP machined oil pump cover
    - cleaned/installed front cover (swapping my Meziere EWP once the old motor is out of the intrigue)
    - installed crank pulley, cover, and harness
    - cleaned exhaust manifold gasket surface (was painted)
    - took motor off the stand and placed in the corner. It's at the point where its ready to be dropped in. All the accessories and top-end will go on once in the car
    - placed transmission on the stand, ready to begin teardown (hopefully Friday night)
  20. #40 Re: Starting to build up the intrigue, finally
    I think I could swing the Friday night; come down after Thanksgiving leave Sunday afternoon
  1. 00' Grand Prix GTP (Build starting)
    By Stinkygrub in forum Members Rides
    Last Post: 04-09-2012, 10:48 AM
  2. trouble starting after topswap/build
    By MrClean in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 11:08 PM
  3. Starting the new build soon:)
    By bballa0740 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 09:34 PM
  4. Carbon Build up / hard starting
    By john breit in forum General Tech Discussion
    Last Post: 03-07-2011, 02:46 PM
