Thread: Chronicles of Elite6's Motor Swap - It lives 8/31
Results 41 to 60 of 72
  1. #41 Re: Chronicles of Elite6's Motor Swap - Dropped in motor with rear header on :0
    That's some good outside of the box thinking. I'm all about farming. Farming being the act of making something work when you don't necessarily have "proper tools" to do the job, a bit of thinking and planning can make it happen.
    I'm still getting my butt kicked by this cold. Wheezing and coughing sucks. I spent maybe an hour on the job. Did the flex bolts, inspection cover, starter, started the fuel line conversion and spent the better part of the hour looking for parts that didn't come in yet. Tightened the diff to engine bracket bolts to the diff, motor mount nuts, oil level sensor, front and rear knock sensors, catback connection...few other things. Started to get sidetracked.
  2. #42 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    Cambridge, Ontario Canada
    Two big problems 1) Won't start 2) I replaced the oil level sensor the big 1 & 1/16th sensor by the oil filter. I tightened it up real good which was a nasty challenge to big with and oil is spewing out of there. Not sure how much more I should give'r on the sensor?
    2005 E55 - stock
  3. #43 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    thats the low pressure sensor. also where you would hook up a pressure gauge.
    the ones i have used had thread sealant on them, you just need to snug it up good, its not going anywhere. i used channel locks to take them out and back in. no room to play with a wrench.
  4. #44 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    I thought I read somewhere that thread sealant was not needed... I didn't use any. I got a socket on it but I am having to use a fair bit of force.
    2005 E55 - stock
  5. #45 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    we are talking about this sensor right? if it has not sealant on it, i'd give it a wrap or 2 of Teflon tape.
    you dont need to bury the threads, just make it good and snug.
  6. #46 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    OK I am totally screwed now. Tried to tighten it up a little more and it got really easy. I backed it out and there is metal everywhere. Trashed the housing threads. Of course, getting to that housing is impossible now. Feels like I pull the motor again (not happening) or I pull the passenger axle. Really depressing man, been working on this for weeks. Might just take it to mechanic & bite the bullet.
    How hard is axle removal? It will piss trans fluid everywhere right?
    2005 E55 - stock
  7. #47 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    It'll leak a little bit not to much.
  8. #48 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    i said snug, and you dont need to bury the threads, but nooooooo........that does suck.
    axle removal should be like nothing at all, if you have the pass side jacked up higher than the drivers side. i lost like maybe 3 or 4 drops when i did mine.
    a lot more fluid comes out when you take the pressure sensor out lol
  9. #49 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    It must have been cross threaded from the start because i was way past snug
    2005 E55 - stock
  10. #50 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    im not 100% sure but the ones i picked up looked like they had tapered threads, meaning they got fatter towards the top.
    also had a fat red ring of thread sealant on it, so it stopped in the middle of the sealant, so i went a tad more and thats it.
    i blew 3 of them things out, so now i have a brass plug in the hole blocking it off completely.
  11. #51 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    London Ont, Canada
    So now what? Tap the block find a bigger sensor?
  12. #52 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    New oil filter adapter or whatever its called. They are removable
  13. #53 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    London Ont, Canada
    Oh ok. Didn't know lol
  14. #54 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    the oil pump spring and shaft are behind it, good time for the up graded plunger and spring. ive been told its like 10 dollars at the dealer.
  15. #55 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    It's NPT threads. FWIW that means they are tapered and seal themselves.
    Holler if you need an adapter. I think there's one on the shelf.
    doing the job isn't easy if you leave the axle in. It's doable though. Personally, I suggest you pull that axle and have access. Clean that gasket surface like you never want to go back into it. Which should be easy ...since you just changed it.
    Little side note on my swap project: extended the: maf, o2, swapped/extended map, swapped all injector pigtails etc etc. Filling with coolant found the end cover of the LIM loose. Pulled TB to fix. Fired up and it tried to rev past 4k. Pulled TB to use thicker/better sealant (no wonder why previous person with this setup had it gooped with nearly a full tube of RTV. Now the IAC may be pissy.
  16. #56 Re: Chronicles of Elite6's Motor Swap - Car won't start & pissing out oil 8/26
    I am going to see if a wreckers locally has an adapter with the sensor already installed so I don't have to mess around with it again. Thanks for the offer though. I cleaned the mother loving stuff outta the surface before dropping motor in - new gasket as well. I currently have the passenger side tie rod disconnected, I should be able to break ball joint loose (new LCA's) - tap axle from knuckle to free it up, yank knuckle out of the way & let axle down. Take block of wood & hit base of axle (that should pop out the clip) then remove?
    2005 E55 - stock
  17. #57 Re: Chronicles of Elite6's Motor Swap - It lives 8/31
    So had to get my butt in gear with the car and with my work schedule I ended up getting her towed to a mechanic. He got it finished up & I drove it home...
    It lives with an off center exhaust
    2005 E55 - stock
  18. #58 Re: Chronicles of Elite6's Motor Swap - It lives 8/31
    What all did he have to do?
  19. #59 Re: Chronicles of Elite6's Motor Swap - It lives 8/31
    Haha he had to do main brake lines, brakes, drivers lca, weld exhaust and redo the whole oil filter adapter thing
    2005 E55 - stock
  20. #60 Re: Chronicles of Elite6's Motor Swap - It lives 8/31
    Jeez how much did that run?
  1. Motor swap
    By Pontiac Man in forum General Grand Prix Discussion
    Last Post: 02-26-2012, 10:27 PM
  2. Another hoodless adventure!
    By bandits grand prix in forum Track Sessions and Kills
    Last Post: 02-11-2012, 12:38 AM
  3. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  4. 3rd motor swap in car
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 05:42 PM
  5. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
