Thread: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Donating Users Tengis's Avatar
    Houston
    I should have three or four of these kits if there is interest - this mount kit was designed by Janice from ClubGP. I have this running on a locals turbo car and the car I took pics of for this which is a big supercharged build thats 350+ whp.
    If anyone wants one Id probably let them go for $125.
    If there is a decent amount of interest I could make more but it would have to be at least in lots of four to keep cost on the main aluminum piece down. Kit consists of 1/2" thick 7075 aluminum mount, steel plate with tabs TIG welded to it, two needed bolts, spacer for bottom bolt, washers, and one nut. The bottom bolt going through the tabs that secures the mount to the cradle is one of your stock bolts that you are replacing.
    Final aluminum piece will be nicely cut on a band saw or water jet cut if I can get them to do it for a decent price. Installing the kit requires you to disassemble some things to gain access, MIG welding (can all be done from above), measuring, and drilling one bolt hole yourself in the aluminum piece (the bottom hole) either after accurately marking the hole with everything already welded and mounted or by drilling the hole on the car.
    This is pretty much everything. The bolt going through the tabs is the stock trans > engine bolt.
    I did all this from above I didnt get the best looking weld but it penetrated nicely and should hold just fine. Also, a suggestion made by Janice is to weld the seam on the front and back of the cradle piece that sits under the mount.
    All bolted up and ready to go.
    Update:
    We have this setup on a car here making somewhere in the realm of 500whp.
    He is maxing his 80# injectors and we will be going bigger with the fuel setup.
    Car has virtually zero vibration in the cabin with this dogbone replacement setup.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Houston
    I figured there would be at least SOME interest in this =p. Less weight, solid, looks better. Ill have a video of the car this mount was on running soon - its going to be a 350+ supercharged setup.
    Satin Purple 97 GTP
  3. #3 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Hows the vibration?
    No worse than poly everything?
  4. #4 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Pennsylvania
    That's really nice. If I had a show car or needed to lighten the load on a track car, this would be fun for me.
  5. #5 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    My other concern is Al subframe instead of steel.
    Thoughts on that one?
    Jan 2009
    Tallahassee, FL
    Those sure do look nice
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Pennsylvania
    Isn't that where the vibrations are eventually going anyway? I mean, trans and engine mount are already there...
  8. #8 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    bracket that is welded to the subframe is steel here.
    Not sure how strong a steel/Al weld would be or hold up as a main motor mount.
    Perhaps steel is the way to go.
  9. #9 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Pennsylvania
    First google result. Does that help? Can I Weld Aluminum to Steel?
  10. #10 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    In other words, guy has to know what he's doing and have correct equipment.
  11. #11 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Portland Oregon
    If you have a decent powered setup, I don't like all the power torquing on the cradle like that. There's a reason the torque struts are mounted to the core support.
  12. #12 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    all mounted to the same place: the frame rails. what is the difference?
  13. #13 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    more stress on subframe bushings instead of core support?
    But core support can't be that strong if they needed fender support braces.
  14. #14 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Houston
    I may be making a bolt in version that will also work with the aluminum cradle. It will require drilling a couple holes obviously.
    Satin Purple 97 GTP
  15. #15 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Now that would be the best of both worlds.
  16. #16 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    the bracket is steel and you welded it to the aluminum subframe? please explain this. Did you use a tig welder with aluminim filler rod or did you use an aluminum mig welder? Also..how long have you drove with that welder to the aluminum?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  17. #17 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Houston
    No. I would never try to weld steel to aluminum. I welded steel to a steel cradle.
    Satin Purple 97 GTP
  18. #18 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Jul 2011
    Michigan
    then where the hell did this steel welded to aluminum bs come from?
  19. #19 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Jul 2011
    Michigan
    i was gonna say, there was no way you tig welder steel to aluminum, because the aluminum has a much lower melting point, therefor the heat would not pentrate the steel before the alumimum melted away.
  20. #20 Re: Dog bone replacement mount setup... no more dog bones! Solid and it saves weight.
    Houston
    Aluminum cradle would require a bolt in mount. Getting down in the engine bay and TIG welding isnt my idea of fun at all.
    We shall see...
    Satin Purple 97 GTP
  1. Solid rubber motor mount
    By jmoore4294 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2011, 04:25 PM
  2. Cheapest solid motor mount
    By Jay7199 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 09:05 AM
  3. Solid steel dog bone motor mounts
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 10-19-2010, 08:32 PM
