Thread: 2007 Grand Prix GXP Struts
Results 1 to 20 of 23
  1. #1 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    I have been searching everywhere and cannot find a solution to my problem. I want all new complete strut assemblies all the way around the car. I can't find any that will fit the 18inch wheel.
    ROCKAUTO has gabriels complete assembly but won't fit 18inch wheel.
    Same problem with All Shock and EVERY other manufacturer.
    What options do I have that won't cost me an arm and a leg?
    Thanks in advance!
  2. #2 Re: 2007 Grand Prix GXP Struts
    Arizona
    Just grab some AGX shocks and call it a day
  3. #3 Re: 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    Quote Originally Posted by 91parkave View Post
    Those will work on 18 inch wheels?
  4. #4 Re: 2007 Grand Prix GXP Struts
    Dec 2010
    DMV
    What does shocks have to do with wheel size?
  5. #5 Re: 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    When I try to order complete strut assemblies, most of them say they're for GXP with a 16 or 17 inch wheel but not the 18.
  6. #6 Re: 2007 Grand Prix GXP Struts
    Wheel size has nothing to do with what strut you can run. As long as it's for a wbody they'll fit
    04 Comp G.
  7. #7 Re: 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    That's what I thought, but why is every website I go on, say... RockAuto for example, it says they have struts to fit the 07 GXP but not 17 or 18 inch rims. Why is that?
  8. #8 Re: 2007 Grand Prix GXP Struts
    Just note that a cheap shock will ride NOTHING like the factory bilsteins.
    They likely say that it can't fit 18's because the GXP was the only car to run bilsteins, as they are better.
  9. #9 Re: 2007 Grand Prix GXP Struts
    They're dumb.. Or they follow what everyone else says.. It's all a wbody.. Wheel size is not going to matter unless your running some weird odd wheel size. Oh and he very least I would run with kyb excel or Monroe or better struts not some Gabriel's
    04 Comp G.
  10. #10 Re: 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    Thanks man, youve already helped ease a lot of stress. Could you take a moment to look at rockauto complete strut assemblies and tell me what you'd recommend for front and back?
    2007 Grand Prix GXP
  11. #11 Re: 2007 Grand Prix GXP Struts
    Yea as far at complete strut assemblies.. All those chooses suck. Your going from Billsteins which are the best strut you can get for the wbody but a) harder to find b) quite pricey and they don't come as a complete setup. Your next best bet would be like 91 suggested kyb agx... But they also don't come complete but if your willing to put in a but of elbow grease you can get new springs (if needed), strut mounts and every thing else and build them.
    04 Comp G.
  12. #12 Re: 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    Thanks man, I appreciate the help
  13. #13 Re: 2007 Grand Prix GXP Struts
    Arizona
    Agx are 123 a shock buy strut mounts
  14. #14 Re: 2007 Grand Prix GXP Struts
    Sep 2015
    Bay City, Michigan
    Won't I need to buy different control arms for the agx to work?
  15. #15 Re: 2007 Grand Prix GXP Struts
    Arizona
    There's that , forgot I'm already on 97-03 style sway bar setup
  16. #16 2007 Grand Prix GXP Struts
    Phil.. Turn your wheel and take a look at your current control arms. If they have a tab and you see the end links are connect from the CA to the sway bar then you already have the 97-03 style CA. If you don't see a tab and the end links are connected from the strut to the swaybar then that's the 04-05 style CA then yes you'll need to swap CA/swaybar
    04 Comp G.
  17. #17 Re: 2007 Grand Prix GXP Struts
    hangover park IL
    only 04 and the first half or so of 05 production had the goofy sway link setup before they switched back to the old style in 05.5
    ~James~ Psychotic Gearhead
  18. #18 Re: 2007 Grand Prix GXP Struts
    SWPA
    That
    Quote Originally Posted by Turbocharged400sbc View Post
    And that
    My 07 GT already had the "97-03 style" LCA's. All the 07's should be that way as well.
  19. #19 Re: 2007 Grand Prix GXP Struts
    Arizona
    All gxp's from 05 to 08 have the strut mounted sway bar link
  20. #20 Re: 2007 Grand Prix GXP Struts
    hangover park IL
    really? you poor schmucks, they stuck you with the defective design leftovers....
  1. I need new struts/spring assemblies for a 2007 Grand Prix GT
    By killain in forum General Grand Prix Discussion
    Last Post: 02-07-2014, 04:00 PM
  2. 2007 grand prix .........please help
    By fentonfamily in forum General Grand Prix Discussion
    Last Post: 05-24-2012, 09:18 PM
  3. 91 grand prix struts
    By stephiekane in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2011, 07:35 AM
