Thread: Passenger side back caliper bracket
Results 1 to 2 of 2
  1. #1 Passenger side back caliper bracket
    SE Level Member wakkamis's Avatar
    Jun 2013
    elgin
    One of the pins got completely seized up, best we could do was to get it to turn a bit, but could not pry it loose. Any one know the best place to get / order these from? I'd also need the pins / bolt / boot to go along. I tried googleing around, but could not find any pins that came with boots and any bracket i found seemed reasonable, but did not come with pins, bolts or boots and then they slapped some "core" price to it that just seems like a load of crock.
    or should i just be looking for a new caliper all together?
    Thanks for any help.
  2. #2 Re: Passenger side back caliper bracket
    Use a map gas torch and heat the sucker up, it will come out with heat.
    But if you need everything else, just buy a new 40 dollar caliper.
  1. 2007 GP Base Engine Torque Mount Bracket Passenger Side
    By eetchickn in forum Wanted To Buy - Parts
    Last Post: 09-04-2013, 05:27 PM
  2. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  3. Passenger Side front and back floorboards soaked... need help
    By DJReed2205 in forum General Tech Discussion
    Last Post: 11-01-2011, 06:26 PM
