Thread: L67 swap
Results 1 to 6 of 6
  1. #1 L67 swap
    Mar 2015
    Miller SD
    Does anyone think when u do a top swap u need to switch tranny and cam?
  2. #2 Re: L67 swap
    Kemmerer, Wyoming
    you don't need to change the transmission, but you can, and might as well put an XP cam with ported heads when you do a top swap.
  3. #3 Re: L67 swap
    Thread title says L67 swap but you ask about a top swap?
    So what do you really want to know? A trans swap and cam swap isnt needed for either. Transmissions arent any stronger between the two, just different gear ratio and a different camshaft is just an option the owner can take if they want more power.
  4. #4 Re: L67 swap
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    #16 year old....
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: L67 swap
    While it's barely worth mentioning. The diff is a smidge stronger and the output shaft is slightly different too.
  6. #6 Re: L67 swap
    Apr 2015
    Columbus, OH
    Heavy Duty, man....
    Top Swapped 01 Imp
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
