Thread: Front caliper mount bolt
Results 1 to 2 of 2
  1. #1 Front caliper mount bolt
    SE Level Member wakkamis's Avatar
    Jun 2013
    elgin
    So found I was missing my lower drivers side mount bolt. The car hadn't sounded right and I just happened to catch the caliper swinging back into position after I parked it tonight.
    Called around to a bunch of auto stores and found no one carries these suckers. One had suggested to find a new bolt from a hardware store. So I'm trying to track down the right bolt size without removing the other one as I still need to the car to go get the part. (really need to get a second vehicle one of these days.)
    Found this on yahoo answers: 14mm x 2 thread, 41mm long
    But I would appreciate a second opinion from a more reliable source.
  2. #2 Re: Front caliper mount bolt
    Enfield, CT
    sounds right
  1. Brake Caliper to Hub bolt
    By GPGT4dr in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2012, 03:57 AM
  2. Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket - 2004
    By jkk9 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 06:40 PM
  3. Stubborn caliper bolt
    By Teancum in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2011, 05:40 AM
  4. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  5. Caliper pin bolt
    By IndeedSS in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2008, 12:29 PM
