Thread: Question about the coolant capacity.
Results 1 to 20 of 22
  1. #1 Question about the coolant capacity.
    Nov 2011
    Virginia
    How much coolant does this car hold? It only took me one gallon of the green stuff to fill it up, plus the additive I put in. Just wondering if this is normal?07 gt
  2. #2 Re: Question about the coolant capacity.
    Define fill. Was it completely empty? Did you do a flush? Did you change out the radiator? Change the thermostat? The amount of coolant needed depends on what you did. I think from completely dry it takes roughly 2 gallons of fluid, do not quote me on this as it has been a long day and my brain is to tired to think.
  3. #3 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Yea I was flushing out the system to switch to the green stuff. I noticed not a lot of the red/brown coolant came out. I ran it on a gallon of distilled water and the coolant flush. Cranked heat and everything. Redrained it and ran distilled water through it til it was coming out clear on the bottom.
  4. #4 Re: Question about the coolant capacity.
    Did you let the water drain out?
  5. #5 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Yea and I read that it was a 2 gallon system. I ran it for 20 minutes with no problems. Gonna check the coolant to see if it looks mixed in the morning I guess
  6. #6 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Yea it was completely drained, even cranked the car and let it run a little before refilling it. I did only use the petcock drain though
  7. #7 Re: Question about the coolant capacity.
    Did you bleed it, there might be air in it. IIRC to properly bleed the system you remove the rad cap let the car run until it is at operating temp with heater on hi, then open the bleeder screw on top of the thermostat housing until straight fluid comes out, then close the bleeder and put the rad cap back on.
  8. #8 Re: Question about the coolant capacity.
    Mar 2014
    Tucson
    Doesn't the owners manual give capacities?
  9. #9 Re: Question about the coolant capacity.
    Quote Originally Posted by BrandonHall10 View Post
    I don't remember.
  10. #10 Re: Question about the coolant capacity.
    the rad alone is one gallon, the block and heater core hold another 2 gallons.
  11. #11 Re: Question about the coolant capacity.
    Dec 2012
    Where 4T65E's were born
    Specs:
    Cooling System Including Reservoir
    3100 V6 (Code J) . . . . . . . . . . . . . 11.0 quarts (10.4 L)
    3800 V6 (Code K) . . . . . . . . . . . . 11.2 quarts (10.6 L)
    3800 V6 Supercharged (Code 1) . 11.2 quarts (10.6 L)
    Sold.
  12. #12 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Would the coolant not cycle through the radiator too though?thoughse the water was coming out clear. I'll flush it again tomorrow by removing the hoses, will that make a difference as opposed to the drain plug?
  13. #13 Re: Question about the coolant capacity.
    how to flush coolant.
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    done.
  14. #14 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Okay thanks for typing that all out for me. I put the garden hose in where I disconnect the radiator hose right? Or in the radiator cap? Also I remember reading I should use distilled water because minerals in filtered water could react or something, is that a big deal? Thanks again for the help.
  15. #15 Re: Question about the coolant capacity.
    garden hose goes to the open radiator.
    ive used tap water for like 25 years with no issues. some are into using distilled water, (its recommended in the manuals) your call. but you'll need a 3 or 4 more gallons to flush with.
    i typed it for the last time a year or two ago lol its saved and i copy paste it now a days.
  16. #16 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Okay I'll probably just go with the hose then. Thanks for all the help!
  17. #17 Re: Question about the coolant capacity.
    **** me if I am wrong here, but don't the fans turn on at 212*?
  18. #18 Re: Question about the coolant capacity.
    Dec 2012
    They're supposed to. Mine come on at like 204 ish lol
    Sold.
  19. #19 Re: Question about the coolant capacity.
    it dont take long 10 to 15 minutes most of the time for the fans to kick on. its cold out now, maybe a bit longer.
  20. #20 Re: Question about the coolant capacity.
    Nov 2011
    Virginia
    Hey do you put some RTV on the thermostat housing or is that rubber ring enough?
  1. Fuel capacity
    By Momof2 in forum General Tech Discussion
    Last Post: 06-29-2012, 06:29 PM
  2. Capacity Specifications
    By Explicit_Spade in forum 04+ Specifics
    Last Post: 12-11-2011, 04:27 PM
  3. coolant capacity of 94 3.1 GP?
    By restlessrobb in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-04-2011, 01:32 PM
  4. oil capacity
    By 3100sfi in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-06-2011, 09:51 PM
  5. Oil Capacity?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 02:33 PM
