Thread: air box removal.....
Results 1 to 6 of 6
  1. #1 air box removal.....
    Sep 2014
    Rockford Illinois
    Hey guys new to the forum... been lurking around awhile finally signed up!!! Some really awsome information here!! Thanx.
    I my first mod removing the air box and install a cone ... anyone see a problem with just removing the box installing the filter right to the stock mass air flow sensor tube??... also made nice little bracket to make sure filter stays stabalized...??
    2005 Grand Prix GTP
    SC CompG
  2. #2 Re: air box removal.....
    its how its done. rip box out, lay the pcm where the box was or zip tie it in, clamp filter to the maf tube. and thats it.
  3. #3 Re: air box removal.....
    SWPA
    That's how I did my initial set up. You can make a custom set up if you want to as well.
    This is my set up.
  4. #4 Re: air box removal.....
    Sep 2014
    Rockford Illinois
    looks sharp where did you relocate the mass air flow sensor?
    2005 Grand Prix GTP
    SC CompG
  5. #5 Re: air box removal.....
    It's what the black coupler is bolted too.
    Filter - tube - coupler - MAF - coupler - TB
  6. #6 Re: air box removal.....
    Oct 2011
    Toledo, OH
    The airbox comes apart in 3 sections, leave the section that the PCM snaps onto in the car. No reason to remove it unless you are doing a fender wall intake as there is plenty of room even for a setup like Stealthee's, and it still has a 3 inch tube pulling colder air in from behind the headlight.
    7"
  1. oil pan removal
    By kyliek23 in forum General Grand Prix Discussion
    Last Post: 09-04-2013, 06:12 PM
  2. s/c removal help
    By Matt Palm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2012, 11:47 AM
  3. h bar removal
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2011, 08:40 AM
  4. egr removal
    By Tony in forum General Tech Discussion
    Last Post: 06-13-2011, 06:26 PM
  5. TB removal
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 12:19 PM
