Good afternoon all,
I own a 2000 Grand Prix GT, and for awhile I've had some groaning from lack of P/S fluid. Added some, it would leak out. Add more, leaks out, rinse repeat etc.
After finally buying a remanufactured A1 Cardone P/S pump & two pressure lines (one with Variable Assist, one without because I don't know which I have and neither did Autozone), I finally decided to find where the hell the leak was coming from.
I finally decided to add some fluid, put the cap back on, and cut the wheel to the right. Dropped under the front right quarter panel of the car, and saw that I have a pretty decent leak coming from the boot on the right side (is there one on the left?).
1. Is it safe to say I should replace the rack?
2. Since I'm already going to be working on that whole bundle of joy, should I keep the P/S reservoir and install that too?
3. Is there an easier way to determine whether I have variable assist or not? I bought the car used and it did not come with an owners manual.
4. On Rockauto, both the pressure line and the return lines come in variable assist and non-V/A versions, so I bought both pressure lines, and I'd like to know which I have so I can avoid buying both versions of the return line as well. Having a decent chunk of change tied up in parts I don't need isn't what I'm trying to do.
Closest videos I found to replacing a rack on a '00 GP GT was EricTheCarGuy's video on replacing the whole subframe on a '99 Grand Am.
If this is in the wrong area, feel free to let me know, I thought some of this might qualify as "nooby" questions. Also, I'm going to go check now to see if there are any sticky's on DIY rack replacements for my model & year.
Thanks in advance!
