Thread: 2000 GTP supercharged
Results 1 to 7 of 7
  1. #1 2000 GTP supercharged
    Sep 2013
    Richland co
    Hi everyone, my name is Timmy and I am new to the forum, I am desp need of help. I am working on a 2000 GTP with running issues. I went to start the car with no prior problems and it ran for only a moment and died.I put a fuel press guage on it and it read 42psi upon turning key on not running, then when I started it the press went to 10psi and died and went back up to 42psi. After thinking about it I changed the pump, filter and relays (not exactly cheap), only for the car to do the same thing. I would pull my hair out if I had any lol. Anyway I started it back up and held my hand on the air intake and it would stay running, so I proceeded to check for vac leaks and found none, not one, grrrr. So I tried to spray ether in the intake and it would stay running, Now I am at a loss, can anyone help please.
  2. #2 Re: 2000 GTP supercharged
    try this out.
  3. #3 Re: 2000 GTP supercharged
    You could also try the unplugging the MAF sensor.
  4. #4 Re: 2000 GTP supercharged
    Sep 2013
    Richland co
    changed the relays 14 and 15, still doing the same thing, its driving me nuts lol
    also unpluged maf and tps seaperately and together
    dont remember if i mentioned but itn would also stay running if I continualy pumped the throttle, when I quit it quit
  5. #5 Re: 2000 GTP supercharged
    re look at the pic up there, you bend a tab out on relay # 15, this puts the fuel pump in hi speed mode, bypassing the resistor thats in the pass side fender. if it starts up, and stays running the resistor is bad.
  6. #6 Re: 2000 GTP supercharged
    Sep 2013
    Richland co
    wow I feel kinda dumb, That worked out pretty smooth. Now im out 300.00 for pump and filter that can't be returned but at least the problem is found. Thank you very much. which resister do you speak of though? that particular relay???
  7. #7 Re: 2000 GTP supercharged
    if your up and running with the tab bent out, you can just leave it like that, or get a new high speed fuel resistor.
  1. 2000 Bonneville SSEi Supercharged
    By Nickell in forum For Sale - Vehicles
    Last Post: 07-18-2013, 06:42 PM
  2. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  3. Trying to mod my 2000 Pontiac Grand Prix GTP Supercharged
    By grandprixgtpsc00 in forum General Tech Discussion
    Last Post: 01-31-2011, 08:21 PM
  4. What's wrong with my 2000 Pontiac Grand Prix GTP Supercharged?
    By 2000 Pontiac GTP SC in forum General Tech Discussion
    Last Post: 05-19-2010, 05:25 AM
