Thread: Slow Start...sometimes
Results 1 to 17 of 17
  1. #1 Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    I have a 99 GTP and it starts slow sometimes. Randomly sometimes when hot sometimes when cold. I changed the cam and crank sensors and it seemed to help a little. I have a parts car available to test parts. Would a control module do this too? Only other thing I can think of is fuel pump/cracked line.
  2. #2 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    It seems like it would be ignition related since you smell fuel after cranking and starting.
  3. #3 Re: Slow Start...sometimes
    Fuel pressure regulator maybe.
  4. #4 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    The FPR looks new as were the cranks sensor and cam sensor although I think they were cheapos like Autozone or something. I could change it easy enough but the randomness has me puzzled.
  5. #5 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    Oh, I also swapped out the MAF sensor as well.
  6. #6 Re: Slow Start...sometimes
    Cleaned the TB plate yet?
    Whats the vacuum/fuel trims like at idle? Possible vacuum leak could make an issue.
  7. #7 Re: Slow Start...sometimes
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Have you tried a Case learn?
    (Crankshaft position sensor Relearn)
  8. #8 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    I haven't done a case relearn yet. Good idea though. The fuel trims were -3 to -5 so a little rich but not too bad.
  9. #9 Re: Slow Start...sometimes
    Jul 2013
    Summertown Tn
    Negative numbers means your PCM is cutting fuel I think.
    So I think you would be lean.
    Don't hold me to that thought.
  10. #10 Re: Slow Start...sometimes
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    -3 to -5 is normal. Not even a brand new car off the lot will just sit at 0. Some older cars will get up in the 8% range and still are ok.
    I believe you are correct that negative numbers mean the PM is cutting fuel but that would not mean he is lean that would mean he is running rich so the PCM takes away fuel to get to (stoichiometric ratio) 14.7:1
    I went NA when a whore left -$300 in my bank account.
  11. #11 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    Negative means it is pulling fuel, you want to err on the rich side. I did not mess with factory tune. Those are short term fuel trims. Onve I get the pulley on I am going to have it dyno tuned on a load bearing dyno. I have not checked fuel trims since my K and N drop in and high flow down pipe and resonator delete. I don't believe a dirty throttle blade has anything to do with it. Case relearn makes sense and iim gonna swap out control modules as I have a spare along with lots of stuff for test parts.
  12. #12 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    Tried the control module and coils, no difference.
  13. #13 Re: Slow Start...sometimes
    I know you said the FPR looks new, but prime the pump and then pull the vacuum line off it, if fuel comes out you know its bad.
    Wouldnt hurt to check anyway, to rule it out.
  14. #14 Re: Slow Start...sometimes
    GTX Level Member blackflag's Avatar
    Virginia
    wire brush your main grounds, 98% its your problem
  15. #15 Re: Slow Start...sometimes
    Aug 2013
    Goshen, Ohio
    Are you talking the engine to body ground and where the battery ground meets the fenderwell? Good tip, I will check it.
  16. #16 Re: Slow Start...sometimes
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  17. #17 Re: Slow Start...sometimes
    Check all the grounds. There are a few in different places all over the engine bay.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. car seems slow
    By jrb1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 10:41 PM
  3. GXP nav is off or slow?
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-18-2013, 04:18 PM
  4. SLOW****
    By 2002 in forum Introductions/Noob Questions
    Last Post: 06-29-2012, 09:36 PM
  5. Does my car seem slow?
    By Toofastgs in forum Off Topic Discussion
    Last Post: 04-18-2009, 07:28 PM
