Thread: roller rocker ratio?
Results 1 to 12 of 12
  1. #1 roller rocker ratio?
    Apr 2013
    Union City, In
    if i get Yella Terra 1.9 rockers do i have to do any head work to support them?
  2. #2 Re: roller rocker ratio?
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    I thought it was just LS6 springs needed with the 1.9s..
  3. #3 Re: roller rocker ratio?
    Head work, no.
  4. #4 Re: roller rocker ratio?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    No headwork.
    Just stiffer springs.
  5. #5 Re: roller rocker ratio?
    Apr 2013
    Union City, In
    Alright i knew i would need springs but didnt know if anymore was needed. Do i have to get different valve covers?
  6. #6 Re: roller rocker ratio?
    Quote Originally Posted by jman44 View Post
    Nope
    04 Comp G.
  7. #7 Re: roller rocker ratio?
    Minnesota
    Springs and retainers I would also change out the valve seals while you are in there.
    But
    I personally would just get the stock modified rockers instead of the more expensive Yella Terra ones. They will work just as well if not better.
  8. #8 Re: roller rocker ratio?
    Springs, retainers, new valve stems and if you need new valve cover gaskets and that's all you need
    04 Comp G.
  9. #9 Re: roller rocker ratio?
    Nov 2011
    NY
    Springs, retainers, new valve stems SEALS and if you need new valve cover gaskets and that's all you need
    air compressor, valve spring compressor and plug adapter if you're going to do the work with heads on engine.
    Not hard to do. Installed 1.9 YT's, ls6 springs and retainers along with new viton seals in a day with lots of beer breaks. You might want to do your LIM gaskets too if not done yet while things are kinda opened anyway. As for the modified rockers, well yeah, they give the same opening, but I vote for the rolling rockers thank you! : )
  10. #10 Re: roller rocker ratio?
    Figured those tools were a giving if he looked until upgrading rockers. Or he could just pull the heads..
    04 Comp G.
  11. #11 Re: roller rocker ratio?
    Nov 2011
    NY
    Lol... After I did mine that way, I felt I should've just pulled the heads and did them too. But I have two other sets (heads) now I can screw around with, lol. So... Will wind up pulling heads soon anyways and swapping a set that's fluxed and going to port/polish them! Hahaha... But it was fun to do anyways, worried like crazy about air pressure dropping and losing a valve into cylinder but was never an issue. Easy with right tools is only why I mentioned them : )
  12. #12 Re: roller rocker ratio?
    Honestly I wanted to avoid pulling the heads when I did mine. Ended up dropping a valve and having to pull them anyways lol and beat myself up for not just doing that originally much easier but then that led me to taking my heads to the machine shop to have them checked lol.
    04 Comp G.
  1. Roller Rocker With Cam Question?
    By youngtearzgtp2013 in forum Introductions/Noob Questions
    Last Post: 03-13-2013, 07:36 PM
  2. What ratio rocker arms can i run with stock springs?
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2011, 11:06 AM
  3. Split ratio rocker question
    By zerolimitsgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2011, 04:19 PM
  4. Rocker ratio
    By gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:29 PM
  5. Roller Rocker Installation
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 12:26 AM
