Thread: slow rpm increase with WOT
Results 1 to 12 of 12
  1. #1 slow rpm increase with WOT
    Jun 2013
    ontario
    Hey, so I've got a 2007 base GP, 86000kms that I just bought last November, (actually bought it on my birthday ). I noticed even from when i test drove it that if I just floored it it would slowly accelerate and my rpms would take 30 seconds or so to go from 2500ish to 4500 for a gear change. However if I only put the pedal down a little, say 10% travel, then I get a massive spike I'm thrown back in my seat and the car takes off until a gear change then I need to find the sweet spot on the pedal again for that gear. Most of the time once I get past 80 kmh its always slow accel, sometimes I can kind of play with the throttle (let off then push down a bit) to find the spot to again make it take off but its harder. Anyone know what might be causing this?
  2. #2 Re: slow rpm increase with WOT
    I bet a good cleaning of the thottle body and MAF sensor would help with the pedal feel.
    As for the wierd issue with your accleration, I wonder if a plugged up exhaust (cat converter) could be a cause.
    Any check engine lights? Does it still have a warranty on it??
  3. #3 Re: slow rpm increase with WOT
    HUDSON
    You cant really go by "seat of the pants" feel when trying to judge acceleration times. Going by "feel" can be very mis-judging. The best thing to do is to do time trials with either a stop watch or goto the race track.
  4. #4 Re: slow rpm increase with WOT
    Jun 2013
    ontario
    Yeah, I meant to do some 0-60mph tests today but I got rained out. Unfortunately I don't really know of any tracks in my area sadly (I'd love to hit one for a day), then I wouldn't be trying to do my tests in fear of the cops haha.
    Correct me if I'm wrong but shouldn't you get max acceleration when you drop the pedal to the floor?
  5. #5 Re: slow rpm increase with WOT
    Jun 2013
    ontario
    at fivefinger: There are no lights on the dash and I had my buddy use his Diablo tuner to see if there were any codes stored in the memory and he said there were none. I actually cleaned the throttle body 2 weeks ago. I disengaged the air flow hose (sorry for lamens terms here), the larger diameter hose where the air enters the throttle body. I got a bottle of sea foam deep creep and scrubbed like no tomorrow with a couple of toothbrushes. It started raining later that day so I didn't get to drive it hard to clean out the carbon and after work that night my car wouldn't start for a few tries. As for cleaning the MAF, how would I clean that? Isn't it just an electrical sensor before the TB? Lastly About the cat converter; I've just run a can of Sea Foam through a quarter of a tank about a week ago, as well as my friend and I did the Sea Foam through the engine via the brake vacuum line so I'm trying to clean everything out as best I can, would that have cleaned up the cat at all?
    As for warranties it had just passed its drivetrain warranty from the manufacturer when I bought it but I bought the 5 year warranty from the dealership (I got the car from a GM dealer) so if there is anything wrong I can get it fixed, the warranty I got covers everything, bloody everything.
  6. #6 Re: slow rpm increase with WOT
    Pics of hose you disconnected? You can pull the maf out and spray either maf cleaner on it or electrical parts cleaner
  7. #7 Re: slow rpm increase with WOT
    Jun 2013
    ontario
    So here is the one picture I'm allowed to add of what I did when I cleaned the TB. IMG-20130623-00110[1].jpg If anyone knows how to add more than one pic that'd be great. But anyways, that center ducting is what I disconnected to allow access to the throttle plate and body. I had to also pull the little hose that goes from the ducting to the engine out (pulled form the engine left attached to ducting), but I made sure I reattached everything.
    I picked up a can of MAF sensor cleaner today and right now I'm about to go take it all apart to clean it.
  8. #8 Re: slow rpm increase with WOT
    You didn't pull the tb off to clean it? Go ahead and take it all the way off and clean it. You can add photos with photobucket.
  9. #9 Re: slow rpm increase with WOT
    Jun 2013
    ontario
    Little update. I took the TP off and gave the body and plate housing a good scrubbing. I may as well do a small review here, I used seafoam deep creep again and let me just say, don't ever bother with it lol. I'm not sure if the deep creep added anything or if it was all just the scrubbing. Canadian Tire sells a throttle body cleaner but I'm not sure if it's too abrasive for seals sensors etc (CRC Throttle Body Cleaner | Canadian Tire) I could only clean as far in as my fingers would allow and I would like to get something to clean in farther but I didn't want to spray anything too harsh in without getting second opinions. I don't have my pictures ready yet but I'll get them up tomorrow. While I had the air ducting off I sprayed the MAF sensor, after everything was said and done the car feels smoother and a little more responsive. I still want to do some tests before I give a final word on it but it feels a little better.
  10. #10 Re: slow rpm increase with WOT
    Jun 2013
    ontario
    So here's all that got clean the last time I tried to clean it without taking off the plate. It's sad really.
    http://i618.photobucket.com/albums/t...624-001211.jpg
    And here is what my throttle body looks like now after scrubbing it with deep creep and a scrub pad. As you can see nothing further in is clean which is why I want to try something that will actually dissolve the carbon on its own.
    http://i618.photobucket.com/albums/t...624-001241.jpg
    http://i618.photobucket.com/albums/t...624-001261.jpg
    http://i618.photobucket.com/albums/t...624-001251.jpg
    As you can see in the last one at the top left I made a mistake, I didn't want to put the gasket side on the ground so I put that side down instead and well I nicked it. Thank god its not something that needs to be flush, next time I'll always put stuff down on some cloths to avoid that.
    One last thing before I go, my repair manual said the torque setting on the bolts is 18 Ft-LBS, so I took my torque wrench but the minimum is 20, but I figured if I did 20 -2 it would be 18. so I was cranking away thinking to myself this was taking allot more than I thought and SNAP! I then had to call around town to find the bolt to replace it. Anyways, for the rest of them I just did snug then 1 half turn, to get it tight.
  11. #11 Re: slow rpm increase with WOT
    Dec 2012
    wichita,ks
    Use the img part then we don't have to chase down your pictures I had this happening in my old work truck. Would also like to know just for future reference
    It is just a FAMILY CAR
  12. #12 Re: slow rpm increase with WOT
    Aug 2012
    westlock alberta
    Dont forget to clean the IAC valve most people do. and btw NEEEEVVVEERRR EEEVVVER use a torque wrenchs upper or LOWER values if your torque wrench goes down to 20ft/lbs at the lowest and you need to torque 20ft/lbs use a different torque wrench. only torque within the 25-75% capacity of the wrench if you go outside that range 9 times out of ten you will break something (as you found out) because it is very inaccurate outside the 25-75% range. just so you know for next time
  1. 97 gtp gone. skyline is replacement
    By blakgtp in forum Members Rides
    Last Post: 07-21-2013, 12:24 PM
  2. How to increase Throttle response on 04+ GPs
    By SF9777 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2012, 05:16 PM
  3. Sudden MPG increase
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-01-2011, 12:58 AM
  4. Mileage Increase
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 02:11 PM
  5. Should I increase my timing
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 03:18 PM
