Thread: 04 Grand Prix GT wont start but power to dash
Results 1 to 3 of 3
  1. #1 04 Grand Prix GT wont start but power to dash
    Jun 2013
    sacramento
    Over month ago ran over a median, to avoid a large plastic object in the road. I hit it pretty hard and blew out both my front tires. Got those replaced and every was fine. A couple weeks ago I was driving home and drove over a speed bump. I was not going very fast, as they were the speed bumps going into my apt complex. After my front tires went over them my car immediately shut off. I had all power to my dash and windows but when i turned my key all the way it didnt make a sound. It didn't crank or even attempt to turn over.
    I pushed it into a parking spot and left it there for a few days and when i returned it started up just fine but as soon as I put it in reverse the car died. I assume from the little jerk putting it in reverse causes. I attempted this two more times with the same result. Everytime I put it in reverse it died.
    I had it towed to my dad's mechanic who said he "thinks" it's the BCM from the fault codes but isnt 100% sure and that he didnt want to tell me that only to fix it and that not be the problem. I towed it to the next shop only to find out the first mechanic wiped out the fault codes and the car wont start again for them to run it until the codes come up again. Hoever the new mechanic thinks it also may be the BCM but his buddy that used to work for Pontiac thinks its the ECM, based solely on my story.
    Has anyone experienced similar issues and does this sound like a BCM problem? I'm clueless when it comes to cars. Any help would be greatly appreciated.
  2. #2 Re: 04 Grand Prix GT wont start but power to dash
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    It does NOT sound like a BCM to me. Any idea if they wrote down the codes before clearing them? PCM would be more likely but codes would help alot.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: 04 Grand Prix GT wont start but power to dash
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Look at your grounds
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Grand Prix GTP wont start
    By Garrett Suderman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 05:43 PM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. no power car wont start dash light barely illuminate need help!!
    By mkedwards in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2010, 07:44 PM
  5. 98 Grand Prix GTP wont start...
    By keioffice in forum General Tech Discussion
    Last Post: 02-01-2010, 04:13 AM
