Yea I changed the oil I'm guna do another oil change nxt week . And in a hose on the top the elbow was cracked so maybe that?
That'll cause a vacuum leak
The hose runs on the top n goes under the throttle bracket. Is that a vaccum hose?
I'd have to see a pic
How do you put pics up?
Use photobucket.
I haven't been driving cause I nedd to replace the radiator but idle is good now sounds good just a knocking sound on warming up but I'm trying to find the correct torque specs for ghe rocker arms I'm finding 13lbs+30ยบ turn , 18lbs and then someone said gm revised it or something to 118lbs. I'm trying to out it on correct even tho it runs fine I wana redo those
18 sounds about right
The knocking was the rocker it torn the threads out I helicoil it. I put the radiator in. But when I was switching the thermostat the one that was in there was longer than the one I got . Is the thermostat suppose to be longer so u have to push it in to keep it in place and flush?
Not sure on that it shOuld be about the same iirc
I'm thinking it might be those ones that allow more coolant flow but I'm not sure
Now when I stoped my car my idle a little rough n dropped n picked up real quick and the car took off by itself real quick. Any ideas of this . My idle I can feel something like rough in my engine i dont really know
