Thread: 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM, alt
Results 1 to 6 of 6
  1. #1 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM, alt
    Jun 2013
    HAMILTON, OHIO
    Hey guys thanks in advance for reading this.....So I have a 98 GP/GT that is having some electrical problems the windows wont roll up or down, no display on the radio, and the interior lights flash off and on for about 10 mins when you first drive the car [each time you get in], and there is no display on the radio but the lights are working on the buttons themselves........ I have noticed that there is some wires dangling by the pedals on the far left side that look like they may go into a relay box of some type [I can possibly get some pics if that may help]. I am not familiar with the car enough yet to know if it is a BCM, ECM, or just a theft deterrent box but the cords are assorted some small some not, could this have anything to do with the windows not working or the lights flashing?! Or is this a different electrical problem more along the lines of alternator or fuse box? ~Any input is much appreciated
  2. #2 Re: 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM,
    Banned
    Jan 2013
    Colorado
    Well start by seeing if those plugs go into anything. Next check all the fuses.
  3. #3 Re: 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM,
    Jun 2013
    HAMILTON, OHIO
    Quote Originally Posted by camopaint0707 View Post
    Ok checked all the fuses, they look good and I got up under the dash, cant find any boxes or places for these wires...
  4. #4 Re: 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM,
    Give us some history on the issue and car. Sounds like you recently got it with these issues.
    Flashing lights would likely be from an alarm, is there one installed?
  5. #5 Re: 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM,
    Jun 2013
    HAMILTON, OHIO
    History is it was bought from a police auction with a salvage title, ran fine and I drove it home. Has always had flashing light so Im not sure when that happened, but I had to put a battery in it last spring and now it needs jumped again....could there be a problem with the alternator causing window issues and flashing lights inside the car? Not really much else.... uhh I also changed the air filter and thermostat when I first got it just for good measure. Fuses all check out but there are some spare wires on the driver side floor some small some big looks like its missing some sort of a relay or control box, any ideas?
  6. #6 Re: 98 GP GT electrical problems int lights flashing windows wont roll down ECM, BCM,
    Please get us pictures. Then pull a door panel off and see fi the windows are hooked up etc.
  1. Windows roll down fine but roll up SLLLOOOOWWLLYYY
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2013, 07:21 PM
  2. My windows wont work.... HELP is appreciated
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-16-2013, 11:30 PM
  3. window wont roll up!
    By natethegreat in forum General Tech Discussion
    Last Post: 01-31-2012, 05:37 PM
  4. rear window wont roll up or down? help
    By 04gtgp in forum 04+ Specifics
    Last Post: 11-07-2011, 06:12 PM
  5. Windows Wont Roll Up or Down
    By MustangMatt96GT in forum General Tech Discussion
    Last Post: 07-11-2011, 06:16 PM
