Thread: Modding Questions
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Modding Questions
    May 2013
    wichita
    Doe anyone know if they make 2step for gtp's if so where can you buy the set up from? and i want to go with a 3.0 pulley what kind of snout do i need to get and what kind of problems mht i run into?
  2. #2 Re: Modding Questions
    Banned
    Jan 2013
    Colorado
    what are your other mods to support a 3.0 pulley?
  3. #3 Re: Modding Questions
    May 2013
    wichita
    Nothing yet its just at a 3.4 pulley and headers and down pipe are goin to be on soon. and of course i tune if i do go with a 3.0 pulley
  4. #4 Re: Modding Questions
    Are you already running the 3.4 pulley? If so I would take that off and put the stock one back on till you can scan to make sure its not knocking.
    I think you need to do some research before you go any further with your car. Most cars can not run a 3.4 pulley without some other mods, be it headers, plog, downpipe, race gas and a custom tune, intercooler to name a few.
    This thread will give you some better ideas of where to start and where you would want to go. http://www.grandprixforums.net/safel...0-a-67580.html
  5. #5 Re: Modding Questions
    Stock snout can run down to a 2.8
  6. #6 Re: Modding Questions
    a two step is something applied to manual transmission cars. you have no idea what you're talking about.
    edit: confused two step (launch control) and anti-lag (turbo backfires).
  7. #7 Re: Modding Questions
    GTP Level Member
    Pittsburgh
    LOL at a 2 step with a Automatic Supercharged car....
    double LOL at running a 3.0 pulley.
    what kind of problems will you run into???....holes in your engine
    2003 SSEi,
  8. #8 Re: Modding Questions
    Dec 2012
    wichita,ks
    So to step in here stop bashing the car has been a year with no scan on the 3.4 and doesn't skip a beat, he wants 2step for the fun of it, and if there only for a turbo car then why does our buddy's 11sec camaro have 2 step. I guess it's to look cool huh and for 3 he does know what he's talking about and so do I we have had boosted cars and worked on a lot and have a friend with a 88 fiero that runs high 11's so we are checking everything as we start to mod... So chill your jets on the bashing there guys...
    It is just a FAMILY CAR
  9. #9 Re: Modding Questions
  10. #10 Re: Modding Questions
    Dec 2012
    wichita,ks
    There's a auto eclipse running 2step so it can happen.. And I was getting one for my supercoupe.
  11. #11 Re: Modding Questions
    I live here. TLSheff's Avatar
    Quote Originally Posted by mudneck4 View Post
    As Bio said, I've only ever known them for Manual Trans cars, so unless this GP has a Getrag swap under the hood, its probably not going to be useful.
    Aside from that, yes he may be on a 3.4 for a year and yes it may "run fine" with "no problems" but scan it and see. I would imagine its pulled so much timing that it's slower than a stock car is. But if it is a glorious god given motor that works unlike most we see, don't blow it up with a 3.0. Listen and do the safe thing, get supporting mods.
    No bashing, but usually, by now, its kaboom.
  12. #12 Re: Modding Questions
    so he pulls the shifter into neutral, two-steps it, and slams it into drive? god dammit kids are stupid.
  13. #13 Re: Modding Questions
    Dec 2012
    wichita,ks
    Oh ya we know to do supporting mods lol that's a given I wouldn't give it long on a 3.0 that's obvious I'm just stating the 3.4 pulley and on the 2step it's just for fun something to play with lol Were putting it on the scanner today or tomorrow idk what day they have setup lol if it is pulling that much timing then how would you correct that because the stock pulley was screwed previous owner somehow bent it that's why we did the 3.4 instead of staying stock pulley. Now I do have a question what is the stock kr? Normally and what is it normally with a 3.4?
  14. #14 Re: Modding Questions
    Dec 2012
    wichita,ks
    I haven't dug into it but somehow it's off the brake pedel when he presses the brake and mats the pedel 2 step is the. Engaged.. He's not a stupid prissy blonde that doesn't know what a tire is(according to your gear drop after 2step.
  15. #15 Re: Modding Questions
    iirc normal can go up to 6-8* KR on some motors. The difference is on a 3.4 6-8* KR is like 16-18* KR on a stock pulley. The smaller you go on pulley, or more mods you throw at the car, the smaller the window is for KR and the motor holding together.
    Ideally, on a 3.4 you want less than 2* KR peak, preferrably 0 KR across the WOT range and shifts if you plan to go with a smaller pulley. Rocking the 3.4 as it is, if its knocking at all, consider running full headers since he wants to drop pulley even more, AL104s, alki/meth/Intercooler setup of some kind... or have him buy a cam and keep the 3.4 and not worry about it.
  16. #16 Re: Modding Questions
    Jan 2012
    Canada
    LOL a 2 step on a supercharged automatic car..... if anything you could just brake boost
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  17. #17 Re: Modding Questions
    Texas
    I think what you mean is a transbrake.
    85 Corvette
    01 TA
    03 Z06
  18. #18 Re: Modding Questions
    Dec 2012
    wichita,ks
    Hes going full headers with downpipe and he has 104's now as of 2 days ago found out both the gold an his gtp were running factory plugs and can he put a fmic on it or does he have to go to a zzp kit?
  19. #19 Re: Modding Questions
    Fmhe? Ic goes under the sc
  20. #20 Re: Modding Questions
    Dec 2012
    wichita,ks
    Alright I didn't know how they mounted, now on this subject if you get a ported sc do you have to have to port the intake?
  1. Modding Questions
    By ms3206 in forum General Grand Prix Discussion
    Last Post: 04-16-2013, 10:21 AM
  2. Need help on modding
    By Dj drek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2013, 12:59 PM
  3. HUD Modding
    By MattF in forum General Tech Discussion
    Last Post: 02-21-2013, 03:42 PM
  4. No more modding my gtp
    By shawnschuldt in forum Off Topic Discussion
    Last Post: 10-04-2012, 02:10 AM
  5. Modding 08 GP GT..
    By 08GrandPrixV6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2009, 09:57 PM
